20 Most Recent General Electric RCA-25424RE1 4-Line Corded Phone Questions & Answers
0answers
3answers
Lost manual. How do I program speed dial?
Hit Store
Enter Number
Hit Store
Select memory spot (buttons down the right hand side of the phone)
11/24/2017 1:25:06 PM • General Electric... • Answered on Nov 24, 2017
0answers
Message light keeps flashing for line two, but
Press/Hold the delete button.
3/21/2012 4:12:00 PM • General Electric... • Answered on Mar 21, 2012
2answers
Message indicator light will not go off even after
I found a solution: Hold the "Delete" button (left button below the dispaly screen) for 1-3 seconds and it will turn off. Figured this out after breaking my head and almost breaking the phone trying to get it to turn off! Hope it helps youl.
1/3/2012 6:02:38 PM • General Electric... • Answered on Jan 03, 2012
2answers
The caller id is not working on one and the ringer
Hello
These phones are not repaired as such, they are exchanged for a repaired unit. I will assure you that you have problems with the phone that need repair. Contact General Electric customer service, the number is in the user manual of Th phone or available on line I am sure, ask them how you can get these phones phones exchanged for repaired/refurbished units.
7/19/2011 12:34:44 PM • General Electric... • Answered on Jul 19, 2011
How to increase volume
To change the ringer volume: while the phone is on the hook press the Vol + or Vol - button. The phone rings according to the current setting. Tap the Vol + or Vol - button to adjust the volume one setting at a time. The phone stores the setting after the last button press.
To change the speakerphone, handset, and headset volume: while the phone is in use in the desired mode, press the Vol + or Vol - button. The phone stores the setting after the last button press.
The above is from pages 14-15 of the manual at
http://www.rca4business.com/products/pc/pdf/instruction-book/25424RE1.pdf
2/26/2011 1:56:32 AM • General Electric... • Answered on Feb 26, 2011
0answers
2answers
Error message "ihibited"...line is working
I will advice you try reset the unit, once the unit is reset, the problem should be fix. Follow this steps to reset the unit,
Turn off the phone, remove the AC adapter, press and hold the page/call button that is on the phone and plug back your Ac adapter, this will fix the problem.
Take care.
9/13/2010 11:44:48 PM • General Electric... • Answered on Sep 13, 2010
I need a manual for this phone how do i get it?
http://www.home-electronics.net/USER-GUIDES/25424_DOM_ES_CD_IB.pdf
8/17/2010 6:29:34 PM • General Electric... • Answered on Aug 17, 2010
Pluged in my phone line and the phone reads Error
Your old phone my have been for a digital phone line. The new phone only works on traditional telco analog. There are adaptors that your phone company has to make the line analog.
7/21/2010 1:06:24 PM • General Electric... • Answered on Jul 21, 2010
When you are on the phone, you can hear the ring
check inside wiring connected to jack for this phone.It is possible old sub-standard category -3 cable was used which would cause inductive cross.If that is the case use cat-5 or even cat-6 cable.The difference is the twists on this cable are tighter ,therefore eliminating most inductive cross.
7/20/2010 4:44:21 PM • General Electric... • Answered on Jul 20, 2010
2answers
Why am I not receiving General Mailbox voicemails?
Hi, Please make sure that the customer is calling the correct number that you think that they're calling. Then, call this number yourself and leave a message before going to check the message again. If you can't find your message, please call the business' phone company and ask them if there are multiple mailboxes linked to your business phone number. If so, they can provide access to the other mailbox for you. Thank you.
12/17/2022 3:18:38 PM • General Lands... • Answered on Dec 17, 2022
General Electric RCA-25424RE1 4-Line Corded Phone Logo
30 questions posted
Top General Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Stan Ford
Are you a General Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
  • General Lands Phones
Most Popular Question
message indicator light will not go off
  • Lands Phones
