20 Most Recent Siemens optiPoint 500 Standard Corded Phone Questions & Answers
The extension name and extension number are set in the system programming. Use manager 'e' and change them in the station view. If you are swapping people around and want them to keep their extension numbers and names, you should re-patch the cables feeding to the wall sockets rather than change the programming (if you can).
Siemens... | Answered on Nov 26, 2014
Hi Steven,
I have this Manual for you on this site, you may want to check the settings for that.
http://www.telcare.co.uk/guides/optipoint500-basic.pdf
Siemens... | Answered on May 08, 2014
Possible fault in the tone ringer IC. This is normally triggered by the incoming signal before the line is switched on. So the IC takes the pulse straight from the incoming voltage , normally from the line in rectifier.
So use a meter to see with a test call for the pulsating voltage on the IC, if present then the IC is faulty. If absent check the inline signal being absent to this section.
Siemens... | Answered on Jan 30, 2014
To add an Extension Key: -
DONT lift handpiece, enter [*91] then press a vacant memory key and then choose “Repdial Key” from the menu. Enter an extension or group number and press the [ü] key.
To dial an Extension Key: -
Lift handpiece.
Press the memory key you programmed.
Storing a personal speed dial number: -
Lift handpiece.
Dial [*92]
Dial memory number.
(*0 - *9 for personal numbers)
Press the [ü] key.
Dial 0 then the number to be stored.
Press the [ü] key.
Hang up.
How to dial speed dial numbers: -
Lift handpiece.
Dial [*7]
Dial memory number.
(001-999 for system numbers)
For Example: [*7*0 ü] will call the personal number stored under position *0.
[*7001 ü] will call the system speed dial number stored under position 001.
Siemens... | Answered on Aug 24, 2012
Siemens optiPoint 500 Standard Corded Phone Logo
65 questions posted
Top Siemens Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Siemens Lands Phones
Most Popular Question
change display name extension using only
  • Lands Phones
