20 Most Recent HP Pavilion DV6700Z Notebook Questions & Answers
Cannot access the internet
I have looked at and reviewed your problem with your HP laptop DV6700Z and have the fallowing for you to aces.
First, if you are trying to access the internet via wireless, wait until you have established and wired connection.
If the blue light comes on in the front panel, the wireless is working, if not, you have a problem with the wireless modem.
Run a wire from your laptop to your modem and enter your my network, choose setup a internet connection.
Try to make a internet connection. Once you have established a connection, you can setup your wireless connection.
Hope this has helped you.
4/25/2018 12:25:13 PM • HP Pavilion... • Answered on Apr 25, 2018
Hp pavilion dv6700 has blank display
If you have access to a monitor plug that into the laptop and see if you have a picture if you have it probably the invertor that lights the backlight its behind the screen at the bottom cheers Sky
4/15/2015 9:41:32 PM • HP Pavilion... • Answered on Apr 15, 2015
2answers
I forgot my password can u tell me how to unlock
HELLO JIMMY,
OK
RESET IT
YOU GO ON SAFE MODE AND CREATE A NEW ACCOUNT . TO GO IN SAFE MODE PRESS F8 BUTTON WHILE BOOTING WINDOWS. ONCE IN SAFE MODE CREATE A NEW ACCOUNT, THEN RESTART THE PC. ONCE YOU RESTART LOG ONTO THE NEWLY CREATED ACCOUNT AND GO:
CONTROL PANEL> ADMINISTRATIVE TOOLS> COMPUTER MANAGEMENT> ON LEFT SIDE SELECT LOCAL MANAGEMENT AND GROUP>THEN SELECT USERS>THEN U WILL SEE LIST OF USERS .
RIGHT CLICK THE USER U NEED TO RESET PASSWORD THEN SELECT ALL TASK SET PASSWORD>CLICK PROCEED> THEN LEAVE NEW PASSWORD BLANK AND CONFIRM PASSWORD BLANK THATS ALL
9/8/2014 6:34:57 PM • HP Pavilion... • Answered on Sep 08, 2014
How do i connect to my tv
need hdmi dvi or vga cable depending on what you have use you video card properties to set it up and there is software made just for doing that basically set you lets say nvidia nvidia control panel multiple screens or clone screen but there is software that does better for money of course
3/4/2013 7:01:01 PM • HP Pavilion... • Answered on Mar 04, 2013
3answers
I forgot my password and lost the disk i cant log in
your solition password recovery sotware
11/9/2011 3:32:57 AM • HP Pavilion... • Answered on Nov 09, 2011
2answers
Bios password reset
The bios password can be reset on the motherboard.
Look on the hp website for instructions on bios reset.
11/2/2011 8:36:06 PM • HP Pavilion... • Answered on Nov 02, 2011
I have an HP Pavilion
Hi
As you mention that it you run the HP health check and I believe that your computer makes unable. to boot up properly.
When booting up, press F8 to go to advance booting option menu.
If there is an option : BOOT FROM LAST KNOW CONFIGURATION, Choose it or otherwise, choose RUN ON SAFE MODE. and follow the below procedure.
Try to go to START
Choosse ACCESSORIES
Right click on DOS COMMAND PROMPT and run as administrator
Then type SFC /SCANNOW and press enter.
Wait to run the scanning problem.
If not, go to START
ACCESSORIES
SYSTEM TOOLS
SCAN DISK for error and it will automatically fixed some errors
When finished try to restart your computer.
If still the same, when you are in the SAFE MODE.
Go to START
Choose RUN
Type MSCONFIG and a system configuration window will pop up
Choose the STARTUP
Then uncheck all the START UP PROGRAMS LIKE YAHOO AND PREVIOUS on you installed before that corrupted your computer.
Also go to SERVICE and then uncheck the HP heath check you installed.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
4/22/2011 3:36:18 AM • HP Pavilion... • Answered on Apr 22, 2011
We have an hp with a built in webcam. i can see
Try to use Skype that is the 'latest' version downloaded off of the Internet. This may be the problem.with no video with an otherwise good camera.
Also, check the the drivers for the camera to make sure it has no errors.
2/6/2011 4:53:49 PM • HP Pavilion... • Answered on Feb 06, 2011
MACK DON'T FONCTION
Hi
Im not sure which mack you have but i found this on the internet
click on the link and see if it helps
good luck
http://www.youtube.com/watch?v=Rjd1ZqJ89N4&feature=related
1/31/2011 8:43:21 PM • HP Pavilion... • Answered on Jan 31, 2011
Can you please tell me
Welcome to Fixya.
As much as we want to obtain the password for you, there is no way we can get this. Your account with them is a secured account and only you can reset or request a password if you have forgotten it.
Should you wish to contact their support, please click this link.
Thank you!
11/25/2010 4:36:43 PM • HP Pavilion... • Answered on Nov 25, 2010
Computer will not open in normal mode, only in
The problem is caused by a program that is set to start at boot. Finding which is causing that will be a very long and complicated procedure. Far faster and easier is to just reinstall windows.
10/22/2010 10:47:05 PM • HP Pavilion... • Answered on Oct 22, 2010
Hi, Nothing happens when I
Motherboard is defective & needs to be replaced with a new one.
You can find a replacement motherboard by searching on e-bay.com with the motherboard's model number. This could be found under the RAM.
10/9/2010 8:02:11 PM • HP Pavilion... • Answered on Oct 09, 2010
I have a HP Pavilion dv6700 special/limited
Sounds like you have a memory problem. Either a RAM module is defective & needs to be replaced, or the slot where the RAM module goes into is not making good contact between the motherboard & the memory module, & needs to be cleaned.
Try first cleaning the RAM module slot with a non-oily contact cleaner. Leave it to dry for few minutes then install the RAM module & test if the computer will turn on. If it does not, replace the RAM module with a working one & test again.
9/19/2010 1:29:39 AM • HP Pavilion... • Answered on Sep 19, 2010
What does it mean if my hp dv6700 won't boot up
This means that your windows operation system is failing. as soon as the computer is rebooted, please try the key F12 on your keyboard (sometimes it's F8 or these keys with the ctrl). See if you have a menu and then press load through Safe Mode. If the windows still won't load, then your windows needs a reboot. If it loads with the Safe Mode, please send me a reply through this post, so that I can further guide you.
6/15/2010 1:22:10 PM • HP Pavilion... • Answered on Jun 15, 2010
My HP Pavilion Dv6700 turns on but nothing on the
Looks like the post itself fails on the system from what you have told here. Its easy to reset the bios. Download the actual bios flash program on a completely formated usb drive. Fix the usb on your laptop and keep fn+esc keys pressed and switch on the laptop. It will rewrite the bios and once rebooted the system should work. Good Luck.
5/5/2010 4:18:14 PM • HP Pavilion... • Answered on May 05, 2010
MY EMAIL ADDRESS IS [email protected]
AOL will allow you to reset it if you ask them ... contact them.
3/8/2010 4:02:31 AM • HP Pavilion... • Answered on Mar 08, 2010
My screen doesnt come on
the screen could be somehow become disconnect with the motherboard. If your screen is loose then the wires could have come loose also. try ctrl f3. i think this is a hardware problem. take it to best buy
2/12/2010 9:46:07 PM • HP Pavilion... • Answered on Feb 12, 2010
Dv6700z power issues.
The power jack on the side of the notebook is either damaged & need to be replaced, or it just needs to be re-soldered to the laptops mainboard.
In either case, the laptop needs to be disassembeled & the jack either re-soldered or replaced.
11/10/2009 4:28:33 AM • HP Pavilion... • Answered on Nov 10, 2009
2answers
Failed intrenal power supply on HP Pavilion dv6700
Before you go thru all that, HP has an extended warranty for 6 and 9K units with Video and Power startup problems.
They have added an extra year to the original warranty and it would be to your benefit to check first.
Email customer care and issue a repair request.
You can chat with a tech and find out in no time yes or no.
If you log a issued complaint, they may review it in your favor.
11/5/2009 6:42:51 PM • HP Pavilion... • Answered on Nov 05, 2009
2answers
Just plugged hdmi to rca wires from laptop to
Are you sure you have identified properly the connectors ? I have never seen such cable : HDMI to RCA. HDMI is digital signal. RCA is analogic signal. You need a signal converter (modulator). Could be expensive.
10/9/2009 3:52:20 AM • HP Pavilion... • Answered on Oct 09, 2009
HP Pavilion DV6700Z Notebook Logo
Popular Tags
53 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Pavilion HP
  • Pavilion HP
Most Popular Question
cannot access internet
  • Computers & Internet
