20 Most Recent Acer Aspire 7520-5185 Laptop Questions & Answers
Acer Aspire 7520 Laptop won't accept password
try typing your password in with the caps-lock on. many times this may go unoticed if both password fiels show * instead of the actual password being entered. if that doesnt work for ya go here and chose one of the 5 options to recover or delete the need for a password. you must first download these and creat an .iso disk to be run at startup.
Good Luck and dont forget to rate my post! :D
5/30/2018 8:11:20 PM • Acer Aspire... • Answered on May 30, 2018
Laptop is cycling on and off
11/19/2017 3:21:22 PM • Acer Aspire... • Answered on Nov 19, 2017
Battery for xps 13 l321x
look on ebay.
4/5/2015 10:36:25 PM • Acer Aspire... • Answered on Apr 05, 2015
Why do computer series turns off alone
I must be going on standby. Check the standby settings. If not it might be the battery problem.
7/22/2014 7:02:50 AM • Acer Aspire... • Answered on Jul 22, 2014
Help. I need to replace my on off switch. How do I
contact the service center.!!!
1/4/2014 11:51:00 AM • Acer Aspire... • Answered on Jan 04, 2014
Touch pad not working
It is possible that the micro switch underneath the button is defective. If this is the case, then the laptop ,(if still under warranty),should be returned to the manufacturer for repair. Otherwise, a new motherboard will be required as the micro switches cannot be replaced.
12/18/2013 11:05:55 AM • Acer Aspire... • Answered on Dec 18, 2013
Acre extensa will not power up with lead, battery
change battery
9/10/2013 5:29:15 PM • Acer Aspire... • Answered on Sep 10, 2013
ACER Aspire laptop power cycles on and off
Sir, form the symptoms I believe that the Battery is completely dead, the system is unable to identify the battery. If possible try checking the battery with a similar model, and the the system should be all set to go.
please encourage us,if this tip was helpful to you.
8/8/2013 7:24:42 PM • Acer Aspire... • Answered on Aug 08, 2013
How do I stop my laptop from reboot loop?
Just insert a windows CD and repair your OS. Your problem will be solved while preserving all your files and folders! Good luck
6/14/2013 4:02:17 PM • Acer Aspire... • Answered on Jun 14, 2013
I have an ACER 7520-5185 that will not boot up. Fan starts to run then shuts off. I have tried swapping the RAM and plugging in to an external display, to no avail. Any solution?
The problem maybe the RAM, it could be faulty or just needs reseating to make proper electrical contact. Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
3/22/2013 1:19:19 AM • Acer Aspire... • Answered on Mar 22, 2013
My acer aspire 7520-5185 will not turn on
Hello. There is a hardware failure with the laptop not the AC charger. AC chargers have some range of protections of their own. If the power requirements of the laptop are bigger then what the charger can handle, the charger will turn off. Also other parameters can bring the charger offline. In your case, you have a problem with a small chip, the battery charge controller unit, witch regulates the amount of current required to propperly charge the battery. When this thing fails, the charging requirements for the battery are reported rong and the AC charger is forced to give more power then necesary. This results in disconnection of the AC charger ( an internal fail safe of the AC charger) and the laptop to swich back to battery power. When the laptop is turned off, it can charge the battery because the power requirements are low, having all processor, main board, hard disk etc turned off. Therefore the AC charger can handle the load. However you will need to have it checked by a service center as it is a hardware fault. Both AC charger and laptop needs that check. The charge controll circuit needs to be replaced probably. It will be a somewhat expensive repair. Don't buy any other battery untill you have the laptop checked.Acer Aspire 7520
1/16/2013 2:41:41 AM • Acer Aspire... • Answered on Jan 16, 2013
Take out the battery then press and hold power button for about 30 seconds, then put battery back in again and try to turn on. Might as well leave it without the battery for some time after holding the power button. If that doesn't help try removing RAM and turning it on without it.By the way.. any beeps?
1/13/2013 2:55:24 AM • Acer Aspire... • Answered on Jan 13, 2013
Where is the printscreen?
on the top of Backspace "prt sc"
12/13/2012 9:10:49 AM • Acer Aspire... • Answered on Dec 13, 2012
Everytime i turn on my acer laptop on it shut's off instantly.. what do i do?
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact. Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
12/13/2012 1:04:13 AM • Acer Aspire... • Answered on Dec 13, 2012
Aspire network key
You had to write it down when you set up the router. Look at the bottom of the router for a post-it note with the number.If this is a permanent part of the router, it might have been in the packaging or could be printed on a label.You might have to reset the router and set up all of the PCs in the house to use a new PIN.You did not give make and model of the router so it is impossible to be more specific.
9/23/2012 2:05:18 PM • Acer Aspire... • Answered on Sep 23, 2012
3answers
I need an owners manual
http://www.intellcity.ru/content-2/service-manual-notebook-Acer/service-manual-Acer-Aspire-7520-7220-Series.pdf here is your service guide to that particular model hope it help Rate me if ive helped Kronoguy
9/14/2012 11:52:07 AM • Acer Aspire... • Answered on Sep 14, 2012
No power
This issue can easily be resolved by http://sureconsulting.in/
9/8/2012 1:58:04 PM • Acer Aspire... • Answered on Sep 08, 2012
Acer Aspire 7520-5185 Laptop Logo
157 questions posted
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
acre extensa will not power up lead
  • Computers & Internet
