20 Most Recent Acer Aspire 4315-2963 Notebook Questions & Answers
Will 2GB DDR2 PC2-5300S Laptop memory work for acer aspire 4315-2963
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. First you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system you should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible
1/28/2013 9:08:59 PM • Acer Aspire... • Answered on Jan 28, 2013
I have acer aspire 4315 intel graphics external display working internal display not working
You can eliminate Graphic Adapter. So the things to check are, Monitor, backlighting, inverter, ribbon cable, on the rear of the monitor, pinched wires, on/off switch, that controls the backlighting when the lid is opened or closed. Here is a video that may give you some ideas: http://www.youtube.com/watch?v=2Yi6GNFcP3w
1/12/2013 2:28:31 AM • Acer Aspire... • Answered on Jan 12, 2013
Replace wifi card acer aspire 4315
This model laptop has WiFi.This WEB site has the specs of this model laptop.http://support.acer.com/acerpanam/notebook/0000/Acer/Aspire4315/Aspire4315sp2.shtml
12/22/2012 8:05:28 AM • Acer Aspire... • Answered on Dec 22, 2012
What is the diffrence between maximum wind speed of 45 mph on jan 1 and 41 mph on feb2
The only difference is 4 mph of speed.
9/12/2012 1:53:13 AM • Acer Aspire... • Answered on Sep 12, 2012
Can not access my emails
You might have some viruses and malware.Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.Download, Install and Run Malwarebytes Anti-Malware:http://majorgeeks.com/download.php?det=5756When Installing choose the non-pro version.Download, Unzip, Install and Run TDSSKiller:http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.htmlDownload, Install and Run Super Anti-Spyware:http://majorgeeks.com/SUPERAntiSpyware_d5116.htmlIf you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.htmlMake sure to select ALL of the "threat categories" when you install or configure Avira.You should be in pretty good shape if you run and install all of these programs.
7/13/2012 11:15:48 AM • Acer Aspire... • Answered on Jul 13, 2012
Number locked letters become numbers
By pressing and holding down the Fn key which is located at the bottom left hand side of the keyboard next to the control "Ctrl" and press the F11 button will revert those numbers back into letter and pressing and holding the Fn key again and press the F11 will turn them back to number. Any further assistance please ask, Kronoguy
6/2/2012 1:34:50 AM • Acer Aspire... • Answered on Jun 02, 2012
91 chevy 454 has miss at idle and low rpm
Wrong place go to the automotive department for that answer this is the laptop section electronics department. John
4/25/2012 4:17:33 PM • Acer Aspire... • Answered on Apr 25, 2012
How to download mxit on my laptop
This is what I came up with hope it assisted you? Click Here........John
4/10/2012 1:48:00 PM • Acer Aspire... • Answered on Apr 10, 2012
Driver vga intel celeron
Go to the Acer site for driver downloads.
4/3/2012 2:41:14 PM • Acer Aspire... • Answered on Apr 03, 2012
Cannot on my computer
hiyou may have bad software drivers. what software did you recently install , if any ? acer has techsupport to address this issue : call 1 855 661 6161go to this Acer site , http://supportforacer.iyogi.com/aspire/blue-screen.html
2/26/2012 9:37:23 AM • Acer Aspire... • Answered on Feb 26, 2012
White screen
Sounds like a loose or bad cable for the display. You will need someone to do some dis-assembly to reveal that cable. Hopefully that connection will be loose and simply snugging it will fix the problem.
1/13/2012 11:11:20 PM • Acer Aspire... • Answered on Jan 13, 2012
3answers
802.11b/g Wireless driver needed for
Which operating system is loaded in your laptop? Try : http://www.computing-tips.net/Solved_Find_Install_Windows_XP_Drivers_Easily/
12/2/2011 5:20:06 AM • Acer Aspire... • Answered on Dec 02, 2011
My acer aspire's screen keeps turning white.
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your ((motherboard to your hard drive)) Sata make sure they have a secure connections and are not faulty or just replace them they could be faulty make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem
a computer needs all of the data and electrical current to travel through every working device and to have an end for a computer to be able work properly
make sure your graphics card is securely seated with no dust in its socket
if you physically remove your graphics to check the socket card restart your computer this should activate found new hardware wizard click start control panel display desktop you can select a different desktop from the drop down list or a browse button where you can select different pictures this may vary depending on your operating system also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size larger size or custom settingsalways click APPLY after making any changes click start control panel display desktop you can select a different desktop from the drop down list or a browse button where you can select different pictures this may vary depending on your operating system also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size larger size or custom settingsalways click APPLY after making any changes click start control panel administrative tools computer management device manager scroll to scroll to monitors + to expand plug and play monitor you might see a yellow question or exclamation mark ? or red x you will have to update the driver right click where you have options to update driver you might download some new graphics drivers http://majorgeeks.com/SiS_UniVGA3_Graphics_Driver_d4401.html
http://download.cnet.com/sis-vga-driver-3/3000-2108_4-164001.html
hope this helps you
10/1/2011 1:59:49 AM • Acer Aspire... • Answered on Oct 01, 2011
3answers
VGA Driver for Acer Aspire 4315 (XP Service Pack
Here's the site to download your VGA driver, http://komku.blogspot.com/2009/04/acer-aspire-4315-4715-xp-vista-drivers.html. Select the VGA Intel then click the download link.
5/3/2011 1:20:23 AM • Acer Aspire... • Answered on May 03, 2011
I want to download the
Go to http://us.acer.com/ac/en/US/content/drivers
Select Notebook, Aspire, 4315 then your operating system (make sure you specify 32 or 64-bit correctly. You can identify this by right-click on My Computer or Computer and click Properties.
Scroll to the bottom. There are two wireless drivers...one for an Atheros chipset and one for Broadcom chipset. I'm not sure which one you are using but it should be defined in your user manual.
4/13/2011 12:29:27 PM • Acer Aspire... • Answered on Apr 13, 2011
2answers
To reset my bios password
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard.
If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove.
If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password.
If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
Many RTC
1/23/2011 8:35:54 PM • Acer Aspire... • Answered on Jan 23, 2011
Can i install bluetooth in
U can make it bluetooth compatible.
But u will have to buy a bluetooth dongle which goes in to one of the USB ports.
11/28/2010 6:59:26 PM • Acer Aspire... • Answered on Nov 28, 2010
Acer Aspire 4315-2963 Notebook Logo
Popular Tags
61 questions posted
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
download mxit laptop
  • Computers & Internet
