20 Most Recent HP Compaq Presario Sr5550f Desktop Pc Questions & Answers
No signal,no power on keyboard or mouse
Sounds like a power supply issue - try to replace the power supply. Many computer shops - MicroCenter, BestBuy.. The power supply is pretty cheap - 15 to 40 dollars US. Search the power supply sticker. Could also be a short, so make sure you can return the power supply with no penalty for it's return - if that doesn't fix the issue.. Hope this helps you.. If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
4/29/2015 7:24:06 AM • HP Compaq... • Answered on Apr 29, 2015
Compaq presario fan placement
You can look for that in any computer shops at your area or try to contact a local tech. and ask where you can get a replacement fan for your computer
8/6/2014 12:38:50 PM • HP Compaq... • Answered on Aug 06, 2014
2answers
Need to install graphics card
Looking at the stats, the computer has a PCI-E(xpress) slot in it. You should be able to put the least expensive card in the system and be fine since you are not gaming. The 250 watt power supply is a bit of a concern. Like most comercially built computers, this one comes with the cheapest power supply Compaq/HP could put in it. I would replace the power supply when installing the new card. Installation of the card is simple. Open the case, look for the expansion slots (near botton of Mother Board), the top slot is the PCI-E. Put the card in, plug all your cables back in (power, keyboard, mouse, ect) before you put the side of the case back on (just in case). Make sure you have the monitor plugged into the new card. Turn the computer back on, in most cases it will auto recognise the new card and use it. When you get to windows, put in the install cd and follow the promts to install the card. If things do not work out this easy, just add a comment to this posting and I will assist you, or someone will.
3/26/2012 6:32:34 AM • HP Compaq... • Answered on Mar 26, 2012
COMPAQ PRESARIO WON'T BOOT FROM
Hello, you are experiencing this because of the Boot priority setting in your bios. Your computer has been set to boot from your hard disk first and so it will never try to boot from a CD when it starts. There are 2 ways to fix this:
1. Go into your bios (usually by pressing F2, F10 or Delete key as your computer starts) and set the boot priority to check CD or optical drives first. Consult your PC manual if necessary.
2. Press F12 when your computer starts, this will bring up a menu to select boot options. Choose your CD drive.
Thanks for using FixYa
7/22/2011 11:00:09 PM • HP Compaq... • Answered on Jul 22, 2011
2answers
Recovery discs aren't working on my hp cq60-615dx, what should I try next?
Appears that recovery disk #2 is bogus. U can try to get a new set from HP (fat chance!) or you can do a reload from a normal, retail OS disk.
6/21/2017 5:57:29 PM • HP Presario... • Answered on Jun 21, 2017
Compac presario CQ62
Hello Most laptop or PCs, has a combination keyboard pressing keys, that invoque the restore routine. usually F11 or F10. others has DVD, check and see what you have of these two. in the first one, you recover from a disk partition the whole OS.
1/26/2017 6:41:46 PM • HP Presario... • Answered on Jan 26, 2017
Bios update fore presario 8000
Its all about go to HP page, and bios updates, the instructions are there too! but be aware you have to be more specific on model, and BIOS dates.
1/26/2017 5:26:29 PM • HP Presario... • Answered on Jan 26, 2017
2answers
Compaq presario sr5350f pc and i keep gtting windows is shutting down everytime i click the help button
You may have a virus, malware, adware, a browser hijacker, or pups (potentially unwanted programs). A. If your computer will boot and you can operate it ok... Download and install Malwarebytes and Superantispyware (Note: If you can\'t do the download on your machine, do it on a friend\'s, put them on a thumb drive, and install them from it). Then scan your computer with each program, and quarantine anything found. B. If your computer won\'t boot, or can\'t operate properly after boot... Tap F8 when you are booting, select "Safe Mode With Networking". Download and install Malwarebytes and Superantispyware (Note: If you can\'t do the download on your machine, do it on a friend\'s, put them on a thumb drive, and install them from it). Then scan your computer with each program, and quarantine anything found. C. If this process finds malware, to keep stuff like that from coming back, I recommend you get the paid version of Malwarebytes.Good luckG
7/30/2014 9:40:23 PM • HP Presario... • Answered on Jul 30, 2014
Macerator is not working
Replacing the Power Supply in HP Pavilion p6000 p6 1000 and p6 2000... BestBuy, MicroCenter, Amazon. Very cheaply priced, very functional. Even the generic brands. Hope this help.. have a great day. OH, make sure you at least match the current power supplies WATTs and it's connection. ? if your information is correct "power supply" If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
5/13/2014 3:47:40 PM • HP Presario... • Answered on May 13, 2014
0answers
0answers
Hp 6830s
If the fan making a smooth spin, but the noise is too loud, then it means the fan is trying to dissipate the heat. Probably the air inlet and or the air outlet (also the fan itself) is dirty (or clogged) and you need to clean it up using a canned air. You may need to open the case/body if the dust become a dust ball (and you need a tweezer and qtip to pickup the dust ball and clean up the fan blades).
3/4/2014 7:59:33 PM • HP Presario... • Answered on Mar 04, 2014
Presario SR5050NX wireless upgrade
Ask The People Who Work At HP To Find Out !
2/18/2014 5:02:42 AM • HP Presario... • Answered on Feb 18, 2014
Dear sir am not getting clear audio sound from my
if u r listening extra vibration sound with actual sound just change speakers
10/28/2013 2:28:06 PM • HP Presario... • Answered on Oct 28, 2013
2answers
Compaq presario cq57: Random shutdown after 5-10
try using a can of Air Duster on the bottom of CP57 where your fan is located to clean out the heatsink allowing your system to stay on and figure out the issue.
9/23/2013 1:52:36 AM • HP Presario... • Answered on Sep 23, 2013
Increase virtual memory
no proberly not,you should never do so.i understand you wan't to add moore memory (RAM)windows 32x can only handle max 4 GB.windows 64x 8-12 GB.invest in some new memory (RAM) that's best.
4/25/2013 1:20:11 AM • HP Presario... • Answered on Apr 25, 2013
Half of my screen has programs bottom is blue
If you boot to safe mode is it the same? What proceeded this issue? Any damage? Updates? Overheating?
4/4/2013 12:18:52 PM • HP Presario... • Answered on Apr 04, 2013
HP Compaq Presario Sr5550f Desktop Pc  Logo
5 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Presario HP
  • Presario HP
Most Popular Question
need install graphics card
  • Computers & Internet
