20 Most Recent Nikon D300 Digital Camera with 18-200mm f/3.5-5.6G ED-IF AF-S VR DX Lens Questions & Answers
The symptoms you describe make it sound like it will not be worth the cost of a rush repair. Because these 18-55 were shipped as part of millions of Nikon cameras they are cheap and easy to come by in camera store and pawn shops.
Nikon D300... | Answered on Jan 09, 2018
If the cable is working fine then check the port on both camera and PC. on the camera maybe there's some dirt or lint stuck on the port try to clean it. On the PC might wanna try other ports usually the one at the back is recommended.
Nikon D300... | Answered on Jun 06, 2017
By virtue of the fact that you are asking this question, I must assume that you are not a qualified camera repair man. Unfortunately, the problem you described is not something you should attempt to repair yourself. It is very likely that your camera has multiple problems. It will cost you less to either send it to Nikon's repair depot or to a camera repair man. If you try to repair it yourself, there is a good chance you will only succeed in doing more damage and increasing your repair cost.
Nikon D300... | Answered on Sep 24, 2014
You cant fix your camera youself call nikon they will advise
if your camera is new they will fix it for free and send it back to you.
Goodluck
Nikon D300... | Answered on Aug 09, 2014
Tip
Nikon D-300
I bought the first D-300 and I love it except for one thing. Sometimes when I take continues shoots the camera will freeze and will not execute the picture. The trick is to slightly move the focus of the lens and the camera for some reason will operate again. I have talked to several experts and they say that this is just part of the camera for what ever reason. Regardless I truly enjoyed all of my SLR and have fun with it. Going digital has been great! Good Luck
on Jan 09, 2011 | Nikon D300 Digital Camera with...
Here are the possible causes and the solutions for each:
Cause 1: The most common cause of the tint in the images is White Balance. It is possible that you have set the wrong White Balance. Since you are getting a blue tint, you might have set the white balance to 'Incandescent' (Tungsten) or 'Flash'. Changing the white balance to Auto. Most White Balance problems get eliminated by this. For this, press WB on the mode dial and use the command dial to change the values.
Cause 2: The unwanted casts could also be due to the in-camera processing. To check this, Select 'Set Picture Controls' from the Shooting menu. From the four options, select one that gives the minimum processing-- that is, either Neutral (which gives minimal processing) or Standard (It gives slight enhancements, but the tones will be balanced).
Cause 3: It is also possible that the White Balance of your camera has been tweaked. So if the above steps do not solve the issue, try tweaking the white balance to your liking. For this, press WB and use the sub command dial (the dial in front of the camera near the Shutter Release button). Check the result each time you change the value until you are satisfied with the result. As a guide, the ideal values of different settings are: Daylight (direct sunlight): 5200; Incandescent: 3000; Flash: 5400; Cloudy: 6000; Shade: 8000 etc...
Nikon D300... | Answered on Aug 26, 2010
Is the camera in airplane or power saving mode?
Nikon D Cameras | Answered on Feb 02, 2019
By not clear do you mean out of focus or streaked due to movement? Try using a higher ISO setting in order to allow for a faster shutter speed and/or use a tripod.
Nikon D Cameras | Answered on Aug 02, 2018
switch button got damage due to hard press so you need to replace it
Nikon D Cameras | Answered on Aug 24, 2017
You can use the Nikon View program that should have been included with the camera. or you download the current versions of Nikon ViewNX or Nikon Capture available free at Nikon Imaging Products Software
Nikon D Cameras | Answered on Dec 11, 2016
Nikon D300 Digital Camera with 18-200mm f/3.5-5.6G ED-IF AF-S VR DX Lens Logo
14 questions posted
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
D Nikon
  • D Nikon
Most Popular Question
friend dropped nikon d3000 floor
  • Cameras
