20 Most Recent Casio Exilim Zoom EX-Z80 Digital Camera Questions & Answers
The camera says in the screen that the card is
I've never fiddled with this brand of camera, but there will be the option to lock the pictures in the menu. In your manual, look for "memory", "locking your pictures", things like that. Also, some memory cards have a plastic tab that slides to lock the card- make sure that isn't in the lock position, if your card has one. Good luck, and hope this helps.
2/9/2014 7:41:21 PM • Casio Exilim... • Answered on Feb 09, 2014
Can a casio camera 8.1 mega pixel ex-29 use as a webcam
Take a look at this.
3/26/2013 5:48:48 PM • Casio Exilim... • Answered on Mar 26, 2013
When I thake pictures outside picture is white
Set your ISO to a lower setting.
10/26/2012 3:23:47 AM • Casio Exilim... • Answered on Oct 26, 2012
Need softwar to down load to my pc
You don't need any software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
9/29/2012 11:11:23 PM • Casio Exilim... • Answered on Sep 29, 2012
Exilim ex-z80 'the card is locked' message
see the video and proceed usign the common sense and logically.God bless you.OTHERwise go to the web page www.casio.comand get the support free via ONLINE chat or phone free
8/3/2012 8:37:13 AM • Casio Exilim... • Answered on Aug 03, 2012
I can't get a new memory card to format it says on the screen that the card is blocked can you help
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
7/22/2012 7:50:53 PM • Casio Exilim... • Answered on Jul 22, 2012
Remove memory card from casio exlim
Push down on the memory card with a fingertip as if to push it further into the camera. This will cause the card to pop out a bit so you can grasp it between your fingertips and pull it out the rest of the way.
5/21/2012 5:01:06 PM • Casio Exilim... • Answered on May 21, 2012
My camera is locking my memory card. I slide the
I have had a similar problem with flimsy lock tabs. I solved it by placing a small amount of scotch tape over the tab - starting near the connection pads, over the tab to the back edge of the card. There's usually not a whole lot of extra room in the slot, so insert carefully and remove portions of tape as needed.
Worst case scenario - if you never use the locking tab (I never do) you could place a small dab of super glue to hold it in place. Let it "set up" before reinserting - you don't want the tab to move an be held on the lock position.
3/9/2012 9:32:01 PM • Casio Exilim... • Answered on Mar 09, 2012
Manual for casio exilim 8.1 camera
If you're in North America, click here. Outside of North America, click here.
12/30/2011 6:37:31 PM • Casio Exilim... • Answered on Dec 30, 2011
Manuels
Please check on the link below:http://www.casio.com/support/manuals/
12/5/2011 11:06:56 AM • Casio Exilim... • Answered on Dec 05, 2011
I dropped this camera accidently in the sand at
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
10/10/2011 10:29:20 PM • Casio Exilim... • Answered on Oct 10, 2011
Casio camera has been dropped and now says lens
Hello
Thank you for using FIXYA!!!
This is a suggestion. If you do not feel comfortable trying it, you will need to take the unit to your nearest service centre. Feel free to let me know if you need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
8/17/2011 12:56:39 PM • Casio Exilim... • Answered on Aug 17, 2011
My sister left my Casio
Hello
Regards
Andrea
8/15/2011 12:37:26 PM • Casio Exilim... • Answered on Aug 15, 2011
LENS ERROR; When i power
Hello
Regards
Andrea
8/11/2011 5:09:26 AM • Casio Exilim... • Answered on Aug 11, 2011
Hi, my exilim won't let
Are you plugging them into the computer to delete them?
7/19/2011 1:29:17 AM • Casio Exilim... • Answered on Jul 19, 2011
Have a casio exslim.
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If that doesn't work, try another card.
7/2/2011 6:25:28 PM • Casio Exilim... • Answered on Jul 02, 2011
3answers
My camera says card locked all the time, it is a
Remove the card and switch the small grey knob on the side of the memory card to the opposite position. This will solve your problem.
5/20/2011 8:59:37 PM • Casio Exilim... • Answered on May 20, 2011
Hallo I have problem. I have
Take out the memory card from the camera. Look at the edge of the card for a very small plastic switch. Change the switch position to unlock position and put the card back in the camera.
Please rate Fixya answers.
4/10/2011 2:04:20 PM • Casio Exilim... • Answered on Apr 10, 2011
Casio Exilim Zoom EX-Z80 Digital Camera Logo
175 questions posted
Top Casio Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Casio Camera Expert? Answer questions, earn points and help others
View Most Popular
Exilim Casio
  • Exilim Casio
Most Popular Question
need softwar down load pc
  • Cameras
