20 Most Recent Nikon D700 Digital Camera Questions & Answers
2answers
Focus problems with Nikon D700
use center fous mode dont keep multi focusing mode
3/9/2022 5:52:42 PM • Nikon D700... • Answered on Mar 09, 2022
Vertical lines showing up on D700 images
Hi Given its age - almost 10 years now, while you don't want drama you can expect them. I had same probs with a Sony - green and yellow lines - then later on a horizontal split in the pics - with the bottom out of alignment with the top. Nikon should be able to quote for a repair - its a quality, full frame camera worth a proper repair. Despite its now small size 12 meg sensor it will still beat a lot of today's cameras in the hands of a good photographer. Cheers Mike
12/11/2017 3:55:30 PM • Nikon D700... • Answered on Dec 11, 2017
My Nikon D700 Camera is sometimes not recognizing
Try cleaning the contacts on the lens and camera with a lint-free cloth and IPA
6/3/2017 11:42:28 AM • Nikon D700... • Answered on Jun 03, 2017
Monitor screen will not turn on.
The problem stated by you is not contain full information. Monitor screen not turning on due to, screen failure, connector flex cut inside, if you can see images on computer means screen has failed. Replace it at a authorised cameta outlet.
4/28/2016 5:52:45 PM • Nikon D700... • Answered on Apr 28, 2016
The monitor screen will not turn on
there are two green buttons on the camera press bot press both to gather at the same time, all top lcd blinks now take a picture and check
6/3/2015 1:05:25 AM • Nikon D700... • Answered on Jun 03, 2015
How do I disable the qual button on d700
why you need it
8/6/2014 5:15:19 AM • Nikon D700... • Answered on Aug 06, 2014
Is it possible to disassemble a nikon d700 hotshoe
Don't attempt to repair your camera if you are not trained. Cameras have many interlocking parts and you may not be able to reassemble everything because it is not always a matter of simply doing things in reverse order. The repair bill will be lower if you don't tamper with it yourself. Contact 1-800-Nikon-US (1-800-645-6687) 9AM-8PM EST, Monday to Friday for assistance.
8/3/2014 5:20:17 PM • Nikon D700... • Answered on Aug 03, 2014
manual
manual
manual
manual
Nikon d700 hotshoe missfire with flash nikon sb900
Probably a loose hotshoe. This is a common problem with the D700 hotshoe and SB900 combo. The weight of the SB900 eventually loosens the hotshoe, meaning the internal screws holding the hotshoe in place loosens.
8/26/2013 10:42:32 PM • Nikon D700... • Answered on Aug 26, 2013
When I plug nikkor 70-300mm 1:4-5.6 D lens to D700, show aputure error.
Turn the aperture ring to its smallest setting (largest f/number). You control the aperture from the camera body, the same was as on a lens without an aperture ring.
12/8/2012 8:02:50 PM • Nikon D700... • Answered on Dec 08, 2012
Can't download from D700 camera to computer
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Nikon Transfer and Picasa.
9/18/2012 11:09:58 PM • Nikon D700... • Answered on Sep 18, 2012
Moving focus
Check the focus selector lock, located just below the multiselector (the cursor pad with the arrows). Make sure it's not in the "L" position, which locks the focus area.
9/15/2012 10:18:08 PM • Nikon D700... • Answered on Sep 15, 2012
Incorrect exposure on NIkon D700
It sounds like you've got exposure bracketing turned on.Refer to the "Bracketing" subsection of the "Exposure" section of the manual (page 130 in my copy). If you need a manual, you may download a copy here.
4/6/2012 5:38:07 PM • Nikon D700... • Answered on Apr 06, 2012
0answers
Nikon D700 Digital Camera Logo
53 questions posted
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
D Nikon
  • D Nikon
Most Popular Question
when plug nikkor 70 300mm 1 4 5 6 d lens
  • Cameras
