20 Most Recent
General Electric A835 Digital Camera Questions & Answers
How do i retieve
If you are using a memory card, take no more pics until you've recovered the photos, take the card out of the camera. This is to reduce the chance of you overwriting some of your "lost" photos. There are many good freeware photo recovery software options that are available to help you recover your photos.
This blog article reviews and outlines several of the better ones.
All the download links listed in the article are through CNET, primarily to verify that these are malware free software, and to give you a chance to read user reviews on the software before downloading.
How would you get pics/videos from this camera to
The best way to download pictures and videos from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures and videos from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa (
http://picasa.google.com ).
Im just asking for the repair services of GE A835
LCD repair is expensive. Best bet is to do it yourself. Buy a used camera through ebay.com (one sold for parts, but with good LCD).Then change the LCD.
A good set of instructions are given in the following sites:
http://camerarepair.blogspot.com/2007/11/fixing-or-replacing-broken-lcd-screen.html
You need to buy a screwdriver set for $1 from Dollar store. That is all you need.
Download softwaer for a835
You don't need any special software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as
Picasa.
Download pictures from camera to computer without download disc
You don't need any special software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
Have a GE a1455 digital camera--how do i get
Take the memory card out of your camera and look at it. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
I have a GE A835
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures and videos from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo/video cataloging program, such as iPhoto and iMovie on Mac or Windows Photo Gallery and Windows Movie Maker on Windows.
Driver for GE A835 digital
Having gone over a month without a reply to my query, I assume my suggestion to use a card reader obviated the need for a driver.
WRITE PROTECT ON WONT LET
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
How to take write protect off
Hi Grandma,
To
remove
the write protect lock, take the memory card out
of the camera, face the card towards you,
look for a small white tab on
the left hand side of the card, to unlock it push the tab up to unlock
it, it will
be at the side of the card like this .
Regards.
For no apparent reason, my
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
