20 Most Recent Kodak Easyshare M753 Slim Digital Camera Questions & Answers
Need to delete protected pictures
Try to remove first the memory card of your camera. After you remove the card you can see a small button at the side of the memory card. Just slide the small button to unprotected. Insert your memory card back to your camera and try to delete pictures.
5/5/2014 6:55:03 AM • Kodak Easyshare... • Answered on May 05, 2014
After clearing the SD card
I'm not into reading manuals, so I can't be sure if that information is there.
You may want to go into the Menu, then select Tools, and either Reset the camera or Format the Internal Memory.
*** There are no warnings when attempting to Reset the camera, but several warnings are displayed when attempting to Format the Internal Memory.
I've never tried it, so don't know which you want to try first.
6/28/2011 12:24:58 AM • Kodak Easyshare... • Answered on Jun 28, 2011
My screen is pink, when
Some symptoms of a defective CCD include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card. A CCD problem would explain the lines on your pictures and the lines on the LCD (since the CCD is used to feed the live image). CCD (Charge Coupled Device) is one of the two main types of image sensors used in digital cameras.
When a picture is taken, the CCD is struck by light coming through the camera's lens. Each of the thousands or millions of tiny pixels that make up the CCD convert this light into electrons. The number of electrons, usually described as the pixel's accumulated charge, is measured, then converted to a digital value. This last step occurs outside the CCD, in a camera component called an analog-to-digital converter.
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details: Bad CCDs
This, isn't a good new, but hope helps to solve it.
Hope this helps to solve it.
6/6/2011 2:10:04 PM • Kodak Easyshare... • Answered on Jun 06, 2011
When i try to turn on my kodak MD41 the light goes
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
9/29/2010 11:37:53 AM • Kodak Easyshare... • Answered on Sep 29, 2010
Can i buy a manual for kodak easyshare m753
Hello
OK, yes, you will be able to order a manual from Kodak themselves.
BUT
I have something you can do to download a manual in PDF format for free. At the link below you will be able to download the manual requested. After the download is complete, you can print it, this is the original manual that came with the unit.
Click HERE to navigate to the download page.
Let me know if you need any further assistance.
Kind regards
Andrea
9/16/2010 9:18:47 PM • Kodak Easyshare... • Answered on Sep 16, 2010
I think i have connected the wrong charger/adaptor
Unless you are lucky the chances are very dim. But take a chance and get teh camera opened to find the right issue . A check on the board will indicate the fault. however if you lucky the prrotection zener would have shorted and saved the main board.
So check this out but take help to open and investigate.
8/28/2010 11:41:09 AM • Kodak Easyshare... • Answered on Aug 28, 2010
2answers
This is embarrassing. How do I release the memory
Were the memory card is, just pull it out
8/20/2010 11:58:56 PM • Kodak Easyshare... • Answered on Aug 20, 2010
2answers
My M753 will not come on. I have put two new
Hi!
The battery contacts seems to be defective please clean them or bend them slightly and then try to charge the battery and power on I think your problem will be solved.
8/11/2010 8:31:16 PM • Kodak Easyshare... • Answered on Aug 11, 2010
L LENS WELL NOT GO BACK IN TO THE CAMERA.
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
4/17/2010 6:21:47 AM • Kodak Easyshare... • Answered on Apr 17, 2010
How do I order a manual for my camera to be posted
You can download a manual for your M753 at
http://www.kodak.com/global/en/service/products/ekn032925.jhtml?pq-path=3905/11249/11250
Please rate this solution. Thanks.
4/2/2010 3:27:50 PM • Kodak Easyshare... • Answered on Apr 02, 2010
BATTERIE DEAD...WONT CHARGE
REmemeber if you're charging the batteries though the computer NOT to switch the camera on. In order to determine the exact fault for your no power issue please try the following: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
1/25/2010 2:50:39 PM • Kodak Easyshare... • Answered on Jan 25, 2010
How do I charge the battery?
You can actually charge this camera right from your computer's USB port. Use the small, rectangular hole and plug the small end of the USB cord into that and the other end into the USB port in your computer or laptoip. The green charging light should come on but the computer won't recognize new hardware since you don't need to turn the camera on. In fact, it will charge faster if you leave it off, so you can just leave that plugged in for a few hours and go about your business.
Hope that helps. Good luck. :)
1/11/2010 10:42:30 AM • Kodak Easyshare... • Answered on Jan 11, 2010
My camera gets hot when I try to charge it,
In that cased Do not charged the battery or turn On the camera You need to call TEch support right away Toll free 1 800 235 6325 EXt 12. Your camera needs for service. The mainboard of your camera is already defective thats why you encouter that problem.
11/12/2009 6:27:37 PM • Kodak Easyshare... • Answered on Nov 12, 2009
Kodak easyshare M753 camera does not repsond to computer
Use a cardreader to download your pictures.
8/18/2009 7:29:35 PM • Kodak Easyshare... • Answered on Aug 18, 2009
2answers
Smashed screen
The price of a new one would probably be the same or cheaper than having it repaired, especially a Kodak. If you recently bought it then it should still be under Kodak's standard 1-year warranty.
8/17/2009 3:26:13 PM • Kodak Easyshare... • Answered on Aug 17, 2009
Wont turn on
Well to be3 a 100% about the battery I would replace it with one that you know or is guaranteed to work. Camera batteries can look OK from outside and be completely collapsed inside.
No Charge lights can indicate NO battery and if there is one inside then it is dead and registers as a no battery ( no charge light)
The red light blinks in very low state, but totally discharged it will not blink and wont blink again until loeft on chareger for about 3-4 hrs to overcome the low state.
7/25/2009 11:52:25 PM • Kodak Easyshare... • Answered on Jul 25, 2009
When camera(m763) is turned on it switches itself
are the batteries dead
7/19/2009 3:18:27 PM • Kodak Easyshare... • Answered on Jul 19, 2009
PRINTER DOCK
ebay's got alot of camera's and docks. i think the one you want is the 600... but you can look for a combo that has your camera model and see which dock number they have with it for better id of dock number... shoot ebays' got everything...
k
5/31/2009 4:41:43 AM • Kodak Easyshare... • Answered on May 31, 2009
Kodak Easyshare M753 Slim Digital Camera  Logo
36 questions posted
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
View Most Popular
EasyShare Kodak
  • EasyShare Kodak
Most Popular Question
when try turn kodak md41 light goes
  • Cameras
