20 Most Recent
Nikon D300 Digital Camera Questions & Answers
Fee error on d300 with Sigma lens with aperture ring
Turn the aperture ring on the lens to its smallest setting (largest f/number) and then forget it's there. You can control the aperture from the camera body, the same way as on lenses without an aperture ring.
Is there a vivitar/minolta lens adapter for nikon body?
Hi, Yes - there are such
adapters. Most of the time however, you lose one or more functions like you do when using extension tubes. These can be metering, auto focus, aperture control on the camera body (must be done on the lens barrel instead), etc.If you have nice Minolta / Vivitar glass, it would probably worth learning to use the camera in a manual mode with these inexpensive adapters. Good luck!
My memory card for D3000 is locked but i checked the card, it seems like the lock is not there how do i sort this out?
SD and Micro SD memory cards SD and Micro SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts.
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Does anyone knows how a Vivitar 75-260mm lens will works on nikon d3000?
Vivitar makes lenses with a variety of mounts. Assuming the lens in question has a Nikon mount then it will fit perfectly well on a D3000. If the lens has a Canon mount, for example, then it will not fit at all.The lens is a manual focus lens, so autofocus will not work. You'll have to focus by yourself.The lens also lacks the electronics to communicate with the camera. You will have to shoot in the Manual exposure mode, setting the shutter speed and aperture yourself, without any help from the camera's light meter.
My nikon d300 indicates full even after
Hi remove the memory card and turn on the camera. Then take pic if that time you seen the same massage then its a internal memory is full. Now just insert the SD card and go in settings. From there set the SD card as default storage location. After that takes photographs & let me know the result.
How to use remote trigger to take a photo with
I'm going to assume you mean the ML-L3 remote. If I'm wrong, please post a comment specifying the remote you are using.
Set the camera's shooting mode to one of the remote modes. Quick remote fires the camera when you press the button on the release. Delayed-response remote waits two seconds to let you hide your hand behind your back before it fires the camera.
The ML-L3 is an infrared remote, so it must be pointed in the general direction of the infrared receiver on the front of the camera.
Tried to remove the EN-EL3e battery from my D300
my battery sticks because I dropped it down a mountain - no joke - the battery compartment is slightly out of shape - you can't really tell - so the battery sticks in. I just give it a gentle tap and it comes out.
What is 15r error message for Nikon D300?
HI there 15r error occour when the memory card is not working properly. May be damaged or virus infected. So i suggest you please replace the memory card and use a new one, your problem will be solve then.
Thanks.
