20 Most Recent
Samsung SCH-U470 Juke Cellular Phone Questions & Answers
What does AA on the display screen mean?
I have an SCH-U450 and had the same annoying AA on my nice wallpaper picture.
Although it doesn't appear in the icon library, apparently, it's for Auto Answer. As soon as I turned that off, it went away.
In my phone to to, Menu > Settings & Tools > Call Settings > Answer Options, and make sure Auto w/ Handsfree checkbox is UNchecked (unless, of course, you want it on, in which case, I guess you're stuck with the AA in the middle of your nice wallpaper picture).
As for the audio announcement, mine was set when I got it to yell out the name of the contact for messages and calls. Try Menu > Settings & Tools > Sound Settings > Call Sounds > Call Alert, then choose Ring Only, or others as appropriate.
Forgot my unlock code to
You may contact to your service provider
Samsung SCH-U470 Unlock Code, they can open up all networks for you where you want to use your phone. Once your phone is unlock, it will work with any networks worldwide without sticking to one network only. I suggest to visit
Samsung Unlock Code site, they will provide an accurate code with easy to follow instructions on how to unlock your phone.
Hope it helps.
Thanks.
I would like to unlock my samsung A867 eternity
Power on without SIM
From the standby screen, press the “Dial” menu
Type in #7465625*638*Unlock code# (8 digit unlock code*)
Device should say: “Network Lock Deactivated”
The 8 digit code can be obtained by calling AT&T Technical Support and given the representative the IMEI number. In exchange they will give you the Subsidy Unlock Code.
To obtain the IMEI number press *#06# on your mobile device
Charging my juke with a usb cord
Fully charge the battery to maximize playing time. However, it
is not necessary to fully charge or completely discharge the battery
each time. You can charge the battery by connecting the jukebox either
to the AC power adapter (fastest) or to a USB port on the computer. The
battery icon in the upper right corner of the screen indicates the
remaining battery charge.
- Connect the USB combo cable to the AC power adapter,
and then plug the power adapter into an AC power outlet. Or, you can
connect the USB combo cable to a USB port on the computer.
- Plug the combo cable into the jukebox. Make sure that the
top of the plug (the side with the arrows) is facing the same direction
as the front of the jukebox.
View Picture
- If you are charging your jukebox from the computer's USB
cable, turn your jukebox off. If your jukebox is on, it cannot charge
from the computer's USB cable.
Note: If you are charging your jukebox
from the AC power adapter, you can leave your jukebox on as it charges,
but it will take longer to charge.
- If the jukebox is on, the power cord icon appears in the
upper right corner of the display. The keypad's backlight turns on while
the battery charges, and then turns off when the battery is fully
charged.
- When your jukebox battery is finished charging, pinch the
two side buttons on the plug, and then pull the plug out of the jukebox.
