20 Most Recent
Nokia 8800 Arte Cellular Phone Questions & Answers
Mic not working
My Dear Your phone mic default so please change mic and mic problem will solved
I have the Nokia 8800
when you receive a call check that the volume is turned up. it's the same control that you use to increase the ringer volume.
Dear Sirs
I have a new
Attempt to make a call by dialing a number on your phone. When the phone rings or when the call has been picked, look at the down right part of the screen, you would see "Loudspeaker" or "Handset". The the button and the call will change to loudspeaker, press again and the call will handset which is the normal way.
Or look at the down left part of the screen, ( I mean the edge), you will see "Option". Press the option button to deactivate loudspeaker.
If the above doesn't solve the problem, then maybe it is a reception/signal problem. To confirm, connect a headset to your phone and make a call. If the call is clear with the headset, then it means it's not a signal problem. But if the headset also echos, then it's a reception problem. You can make the call in another direction, you could go out of the house or upstairs for more signal.
Another possible cause of this problem is cause by Television or Radio radiation. If your TV or radio is on while you are receiving or making calls, this can cause echo.
Lastly, you can just turn off your phone, remove the battery and Sim card (if any). Insert them back and turn the phone on again. The try again.
I hope the above helps. If it doesn't help, please let me know so that I can direct you further on what next to do.
I wish you good luck.
Take care!
My vibration has stopped working
That is a great phone.
The nokia menu system is confusing - when you change from 'silent' to 'normal' to 'outdoor' or any other setting, the entire ring profile changes.
I think what you have done is switch profile to a setting where the vibrate is not set to on.
simply go into the menu, select vibrate, and turn setting ON.
be aware that if you change from this setting, it may go OFF again.
Good luck,
Please vote for a positive rating for me.
Scott
My phone showing sim invalid
take out battery and sim clean the little slot were the sim goes and the shiny golden parts on the sim with a cotton swab wait 30 seconds then put it back together hope this helps(please rate and vote)
I have nokia 8800 arte
I have the Nokia 880 Arte mobile, when making a call can not hear the other in the ear piece
Can i make text larger?
Hi there
Yes you can make a text larger.
Click on message>message settings> general settings> font size. click on font size to choose the size you want
Cheers
How to change language in NOKIA 8800 Arte .
If there is no Arabic in the Phone how can you switch to Arabic? Not possible unless you re-install the firmware with Arabic as an option. Go to Nokia Care and ask them if they have firmware with Arabic as an option.
Bought new phone, won't turn on
please check the connector of the battery and with any thing try to close the connector ,
try another batt if sill dead try to do software
