20 Most Recent Goldstar MV-1515 Microwave Oven Questions & Answers
Not all buttons work on touchpad
There will be a problem with the touchpad membrane, usually this is usually repaired by replacing the complete touchpad facia or front control panel.
11/11/2013 12:21:18 AM • Goldstar MV-1515... • Answered on Nov 11, 2013
1515w
You can order Goldstar / LG parts from Encompass here or you can call them toll-free at 866-779-5835. The model number would be MV-1515W if it's white, and MV-1515B if it's black, but those parts will be the same in both versions.If you're having trouble with the cooktop lights either staying on or not coming on after they have blown and been replaced, your need your control circuit board repaired. Details are here.
6/10/2013 4:56:37 AM • Goldstar MV-1515... • Answered on Jun 10, 2013
What is the manufacturor height clearance from the top of the stove to the bottom of the microwave?
That will be found in your installation instructions.if you don't have them, post a new help request and include the full model number from the tag in or on the oven so we can help you further.
5/3/2013 10:38:49 PM • Goldstar MV-1515... • Answered on May 03, 2013
Handle on goldstar microwave came off
Going to have to search with the model number and Google to see if a part is available for this problem---how old is the unit?
6/16/2012 7:20:40 PM • Goldstar MV-1515... • Answered on Jun 16, 2012
Kennmore ultra wave shut off
LG's service manual troubleshooting section suggests the F9 code could be due to line voltage, magnetron, inverter module, "Relay 2", or a loose connection between door/magnetron/control PCB (Power Control Board).
Other indications might help narrow down these choices before having to pull out your multimeter and crack open the microwave case; for example, if the microwave works, but heats slowly, then the troubleshooting manual narrows your choices down to magnetron or line voltage problems, and pretty much rules out the other possiblities.
In other cases, F9 error code indicates an inverter failure. This can sometimes by caused by a power surge or glitch through the electrical lines. You can sometimes clear this fault by completely unplugging the microwave for 1 minute. Plug it back in and see if the fault code returns. If it does, then you have an internal component failure that will need to be serviced by a technician.
Hope this helps (remember to rate this answer).
9/9/2011 1:15:37 PM • Goldstar MV-1515... • Answered on Sep 09, 2011
My microwave makes a buzzing sound when i turn it
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ';
9/1/2011 11:22:40 AM • Goldstar MV-1515... • Answered on Sep 01, 2011
Door has two cracks on bottom rail. How do I get
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
1/4/2011 4:12:37 AM • Goldstar MV-1515... • Answered on Jan 04, 2011
My circut breaker keeps triping. i need to know
Most domestic microwave ovens draw arount 1kWatt on microwave and the same again for convection.
If it is a European country (230Volts) maximum power will be 10 Amps, 20 Amps on 110Volts.
If the breaker is an RCD type, you have an earth line fault!
12/14/2010 2:34:17 PM • Goldstar MV-1515... • Answered on Dec 14, 2010
We turned it on with nothing in it and it made a
Here is a tip that I wrote that will help you with that...
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
8/12/2010 2:00:23 AM • Goldstar MV-1515... • Answered on Aug 12, 2010
Gold Star 1515W microwave not heating up and when
The magnetron (the part that heats the food) may be bad or the circuitry to the magnetron may have burned out. Basically my advice is that if you have no electrical expertise, it isn't worth fixing. The magnetron if bad, costs almost as much as a new microwave. If you open it up (make sure it has been unplugged for a few hours and don't seen any obvious burnt parts, then most likely the magnetron is done and a new microwave is the way to go.
Let me know how this works out for you.
Benjamin
7/20/2010 2:07:14 AM • Goldstar MV-1515... • Answered on Jul 20, 2010
Everything seems to be working but will not cook
This happens because of a bad door switch . The plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door .
Check also the turntable . It could be out of it's right place .
WARNING :
1:Don't slam your microwave door because this may cause the fuse to blow and this is the reason of bad door switch problem .
2: A microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
4/13/2010 6:58:51 PM • Goldstar MV-1515... • Answered on Apr 13, 2010
2answers
Kenmore Ultra Wave Microwave has no power
after removing the cover of microwave chk for continuty of cavity thermostat usually calld TCO(thermal cut off). it is located on top of the cavity and circular in shape.usually neutral wire goes through this 2 control board and this TCO is for protection of cavity from overheating.if this tco is open.then replace it.usually this happens when u cook for 2 long.
1/31/2010 5:29:24 PM • Goldstar MV-1515... • Answered on Jan 31, 2010
Need installation instructions how to mount
Hi manuals can be downloaded from here
http://www.lge.com/us/support/index.jsp
Or www.fixya.com
Hope this helps
1/7/2010 2:39:00 PM • Goldstar MV-1515... • Answered on Jan 07, 2010
Need to install goldstar mv1515b otr microwave but
you can not get a plate . only plate that mounts it is the one that came with it . now I did this with my own sharp and this wil work with any . cut the wall benind same size of micro / this will let you slide it into the wall almost 3 in . giving you more room to cook and work on range top. she loved this . then attach the front by the bolts from the top or screw/s to the side of both .. makes a neet install ..****/ feed back pls .. dont forget the power goes in the top ,,
12/23/2009 11:42:52 AM • Goldstar MV-1515... • Answered on Dec 23, 2009
Goldstar MV1515W running but not heating
One of two things will be the problem. 1)almost certainly the magnatron. 2)the cap and HV diode need to be checked and possibly replaced.
9/17/2009 5:13:24 PM • Goldstar MV-1515... • Answered on Sep 17, 2009
Microwave may have overheated
There are two thermal protectors which may be blown. If so, it will measure open (infinity) instead of closed (zero ohms).
One is located on the magnetron and one is on top of the oven cavity.
(There is also one located on the floor / base of the microwave but that one's not at issue.)
The magnetron thermal protector *may* be accessible by removing the control panel, but to access the oven cavity thermal protector, you will have to remove the oven from the wall.
If so, the installation instructions here are very handy, and it's best to have two people since the microwave can be heavy and awkward.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
7/14/2009 1:43:04 AM • Goldstar MV-1515... • Answered on Jul 14, 2009
Microwave Ovens Logo
37 questions posted
Top Goldstar Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Goldstar Microwave Ovens
Most Popular Question
door two cracks bottom rail get
  • Microwave Ovens
