20 Most Recent
Franklin Industries Franklin Chef FIM200 Ice Machine Questions & Answers
Machine runs cold water but will not make ice,
Check the condenser coil to make sure it is cleaned out, also make sure the condenser fan is no dropping out. Next check to make sure the water fill valve is not seeping water past into the sump tray if so than it will not freeze, Water will get cold but not cold enough to freeze check water temp in sump tray with a thermometer to make sure it is getting down to 32 deg.
7/10/2014 4:43:57 PM •
Franklin...
Answered
on Jul 10, 2014
How do I clean my FLM70 ice maker
Google Franklin chef FIM70 Ice maker- compactAppliance.com, click on page scroll down page until you see Download product owner's manual ( PDF ) this will give you step by step instructions on how to clean your machine, The machine should be cleaned every 6 months. If cleaning dose not help with the problem than you need to look into a harvest problem.
7/10/2014 4:08:02 PM •
Franklin...
Answered
on Jul 10, 2014
Fim200a does not make the cubes large enough
If you just started having this problem now and it was making the right size ice before then i would first look at cleaning the ice machine including the condenser coil. second thing make sure that the water inlet valve is not seeping water by when it is in freeze mode just a little warmer water will cause it to not make good ice and a longer freeze time. last thing would be to adjust the I.S.Adjust: Ice size adjustment on the control board. Turn screw clockwise, and the size of individual ice cubes will be larger in the next cycle; the cycle time will be longer. Turn the screw counter-clockwise, and the ice will be smaller in the next cycle. only do this if every thing ealse checks out good.
7/10/2014 2:07:54 PM •
Franklin...
Answered
on Jul 10, 2014
