20 Most Recent
Logitech Z Cinema 2.1 2.1 Speakers Questions & Answers
Our power went out last
Chances are that either the soundcard or speakers on your pc have been damaged by the sudden power/surge outage.
Suggest you try youy speakers on another pc or connect to your TV to test them. If they work fine, try putting some earphones/headphones into your pc (same connector as the speakers) to see if they work there.
Either way, from the above you will be able to tell what's broken. If the soundarc on your pc is damaged, you will prob need to take to someone to see if they can fix or replace the part. They may need to replace the whole motherboard.
Hope that helps, pls rate the solution
No sound on Logitech Z Cinema 2.1 speakers.
1. Check Output cable properly connected to the computer in Green socket.
2. Check computer Volume Balance.
- go to start- control panel-sound & game controller
- check ur volume mute/unmute, volume all balance
3. check sound drivers/update driver
- go to - My Computyer - right click - properties - hardware - device manager - check sound hardware - Uninsall all sound driver
- Then Scan in device manager. it will automatically install again.
4.Then check output volume.
Need manual for Z Cinema
Hi bud , Please go to the link provided to find your manual, Just choose your right model Code , and download the Manual
Happy new year Bud
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=8040&p_created=1204577470&p_sid=74U3_aRj&p_accessibility=&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MywzJnBfcHJvZHM9JnBfY2F0cz0mcF9wdj0mcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1aIDIzMDAgMiAxIFNwZWFrZXIgU3lzdGVt&p_li=&p_topview=1#Home+PCSpeakerSystems
Logitech Z-Cinema Speakers.
I have these. Just hook up via usb cable. However, to make them work, you have to get the driver for them off Logitechs website. Here is the link : http://www.logitech.com/index.cfm/439/3712&hub=1&cl=us,en just click on the "downloads"button and select your operating system and you can find from there.
Can't get out of mute
Check you computers volem controll and then the speakers voleum and you conecsions this may be your problem
