20 Most Recent
TREND Motor Trend Inverter 2400 Watt 400-Watt Power Supply Questions & Answers
My Motor Trend Inverter 400 watt give's me a fault
Sadly replacement is the best option. It is just not cost effective to get the inverter repaired.
The cost starts out about 150.00.
Best option is to take it back to where you purchased it and hope you can get a new one.
Hope this tip helps.
Am a seven each power inverters owner.
Recommendations: Purchase a Pure sine inverter 1500 watt. We have had one of these running 24 seven for almost a year now.
Motor trend 2400 watt inverter has 147 VAC from both hot and Neut
Assuming you are testing alternating current and not direct current that sounds quite normal. Plug with confidence. You are using equipment designed for 110v-120v and you're getting 113.8v where it matters most. Higher voltage to ground is nothing unusual, that's just how this inverter is designed.
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
I need a product key
Have you actually purchased Visio, or are you just trying to get it for free?
As a software guy, I would have to advise against piracy. :)
There are several ways to get Visio for cheap. If you are a student, there are discounted versions available online and in stores. Also, you can check with your school for even cheaper options sometimes. Try the university bookstore if available. Or a Computer Science department maybe.
If you are working, and your company uses MS Office applications, find out if they have the "Microsoft at Home" program. You can get MS Office applications for really cheap that way. I can get Visio through my company's "Microsoft at Home" program for a few dollars.
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
