20 Most Recent
Euro Style 04389WHT Freddy Adjective Bar Stool in Questions & Answers
What is an adjective for hamburger
Haussmann Inc.Note: Applies to all productsCleaning and MaintenanceCleaning is best accomplished by using warm lightly soapy water. Use of a dishwashing soap with a citrus base isbest. Simply wipe the item with a wetted damp rag and then wipe dry with an absorbent dry towel. To maintain luster use a spray on furniture polish like Lemon Pledge. Direct exposure in the sun light will make the oil fade due to UV rays. Over time the oiled surface can be refreshed by cleaning and then applying a light coat of neutral natural wood oil.The original Livos oils use are not from manmade chemistry or petroleum based products. They are from natural plant chemistry and are water resistant and food safe surfaces.Note: Natural wood with natural finishes packed in cardboard boxes may develop surface mold due to air moisture and contact between cardboard and wood. The wood is a natural heat sink and warms and cools creating moisture inside the box. The wet cardboard causes surface mold to form occasionally. After removing from the cartons simply clean as above. The piece will adjust to its new climate and stabilize over time and the surface mold will stop forming.
I have a simmons nuflex bed that is fine except the foot wont raise. Massage works on foot, but it just wont lift. No clicking or noises when using the remote
If the foot of your Simmons Nuflex bed will not raise, there may be an issue with the motor or the lift mechanism. Here are a few things you can try to fix the problem:
- Check the remote control: Make sure the remote is properly functioning and the batteries are not dead. Also, check that the foot lift button is not stuck.
- Check the wiring: Check the wiring between the remote, the lift mechanism, and the motor for any frayed or disconnected wires. If you find any damaged wires, they will need to be repaired or replaced.
- Check the lift mechanism: Inspect the lift mechanism and look for any visible damage or debris that may be preventing the foot from raising. Clean the lift mechanism and lubricate it with light oil.
- Check the motor: If the motor is not functioning properly, it may be preventing the foot from raising. If the motor is faulty, it will need to be replaced.
If you are not comfortable with these steps, or if the issue persists after trying them, it may be best to contact Simmons customer support or a professional technician for further assistance. They may ask you to provide your bed's serial number and other information to help troubleshoot the problem.
4/17/2024 2:20:33 AM •
Furniture
Answered
on Apr 17, 2024
What is the best wine cooler in the market?
The NewAir AW-210ED is by far the most successful wine cooler
there is making the best wine cooler overall for the price. The only downfall
is that this specific model doesn't have the highest capacity for the price.
3/27/2024 2:23:42 PM •
Furniture
Answered
on Mar 27, 2024
Which brand provides the best wine coolers?
I don't know but if I needed to find out I would look first at the brands used by commercial establishments that buy for long life and reliability.
While it is fashionable for wine to be overcooled, my father's words often come back to me, "if a drink has to be chilled to taste good, it is poor quality".
White wines and pale beers are traditionally kept in a cellar.
Cellar temperatures are between 45 and 54 F; comparatively mild temperatures that for most of the year in the temperate regions no refrigeration is needed...
3/27/2024 2:20:04 PM •
Furniture
Answered
on Mar 27, 2024
How long can you keeo sherry cooking wine?
Though sherry tends not to spoil in the traditional sense, this fortified wine actually does have a shelf life. Most types of sherry can be kept unopened for up to three years, however Pale Cream sherries have a shelf life of two years, and Fino and Manzanillo sherries have a shelf life of no more than 18 months.
3/27/2024 2:13:44 PM •
Furniture
Answered
on Mar 27, 2024
What are the advantages of buying a sofa bed?
Sofa
beds are a great solution if you don't have a spare room for guests and want
the option of having people to stay over. During the day it can function as a
couch and at night turn into a bed.
3/24/2024 12:25:41 PM •
Furniture
Answered
on Mar 24, 2024
How do I get the right furniture for my event in London?
The best thing you can do is turn to a company that provides event rentals. I have worked in the industry for years and have always found that renting is easier than buying. Buying means storing the stuff, keeping it in good condition, and ensuring it always matches your event's theme. With an event company in London, you can choose what you need as each event requires.
Some great choices for a company can help you get your hands on the furniture you need, including
Velvet Living. Leave the buying to the event companies; you can just rent what you require, so you never have to worry about storing the equipment or adjusting themes and event settings to suit your available furniture.
3/7/2024 12:06:20 PM •
Furniture
Answered
on Mar 07, 2024
