20 Most Recent
Toshiba Replacement Keyboard Questions & Answers
Hello. some keys like "6,y.u.w
if it is a laptop keyboard that is not working but you want to use an external keyboard just buy a usb one. Typically if you are running an windows xp or newer, it will just recognized the keyboard and you will be fine.
PS2 is that round plug with 6 pins you would find on older computers.
If you did not want to use an external keyboard and want to try to fix the the internal laptop's keyboard, there are a few things you could try:
1'st, shoot the keys with air duster to see if you can dislodge anything stuck under them.
2'nd, you can pop off the keys and press directly on the contact to see if the button works.
3'd, if that doesn't work you can take off the keyboard and ther will be a part number on the bottom of it. type that into google and you can find a place that sells replacement keyboards.
I did this on a Toshiba satellite and it worked fine, just be sure not to break the keyboard ribbon connector on the motherboard when you remove it.
9/15/2011 6:05:37 AM •
Toshiba ...
Answered
on Sep 15, 2011
Keybord stop working can you
Depending on the model, most just remove the top cover closest to the top of the keyboard (snaps on or off) remove the two sometime three screws, Lift carefully not damaging the ribon. Romove and replace repeat in reverse order.
8/10/2010 1:31:10 AM •
Toshiba ...
Answered
on Aug 10, 2010
Find replacement keycaps for toshiba satellite laptop
You can get replacement keys from this company that i used a few months back when i lost two of my keys.They sell genuine keys with their retainer plastic pieces for just $5.
Browse through your brand name, model number and order your required key. It’s
that simple. The best part is, you can repair your broken keys yourself by watching the
video tutorials on the website.
check:
http://www.laptopkey.com
3/29/2010 9:49:19 AM •
Toshiba ...
Answered
on Mar 29, 2010
Letter ''Y'' not working in keyboard
You might be attacked by a virus, so scan your PC with antivirus thoroughly. If it doesn't work, try my last powerful way. Follow me how:
Click Start Button>All Program>Accesories>Accesibilities>On Screen Keyboard. DONE!
If you find it unsatisfied, Try to Remove the OFFICE, and re-install it! GodLuck!
6/27/2009 11:12:33 AM •
Toshiba ...
Answered
on Jun 27, 2009
Tecra 8200, I have bought a replacement keypad
take it to a shop. because i know how to do it but you hav to take the whole cover of the laptop then take the old one off and put the new one on the screw everything back. the thing you shouldnt have bought a new keyboard. because its not the key pads its probably the panels under them might be meesed up. but you can try to open it up and install the new one but one mistake could cost you $100 or maybe $200 so the chance is pretty risky
12/3/2008 3:52:07 AM •
Toshiba ...
Answered
on Dec 03, 2008
Toshiba washing machine model AW-DK1700WMM has turn on, beeps with error code EL then shut down within 5 seconds, how can I slove this problem?
To fix the EL error code:
* Make sure the door is completely closed and latched securely. A loose or broken latch can cause the error.
*Examine the door lock for any damage, dirt, or debris that could prevent it from working properly. Clean the area thoroughly.
* Turn off the washing machine, then unplug it for a few minutes. Plug it back in and restart it. This may resolve communication issues that trigger the error.
* Examine the wiring connections between the door lock system and the control panel. Faulty connections, such as loose or damaged wires, can disrupt communication and lead to the error message.
3/26/2024 1:48:19 PM •
Toshiba...
Answered
on Mar 26, 2024
How to fix tablet toshiba wt8-a
Ensure the cd rom is empty and the bios is set to boot from drive C first, then drive D.
If all in order and it still doesn't boot, try a system disc in the cd rom.
10/11/2023 4:56:30 PM •
Toshiba...
Answered
on Oct 11, 2023
Toshiba Strata CHSU40A3 no display or tone
If your Toshiba Strata CHSU40A3 phone system is not displaying anything and there is no dial tone, there could be a few reasons for this issue. Here are some troubleshooting steps you can try:
- Check the power source: Make sure the phone system is plugged into a functioning power outlet and the power adapter is working correctly. You may also want to try plugging it into a different outlet to see if that helps.
- Check the connections: Make sure all the cables and cords are connected properly. If the phone is connected to a network, check the network cables as well.
- Reset the phone: Try resetting the phone system by unplugging it from the power source and plugging it back in after a minute. This will help to clear any issues with the phone system.
- Check for any damage: Inspect the phone system for any physical damage, such as cracks or breaks in the casing or any loose components. If you find any damage, the phone system may need to be repaired or replaced.
If none of these troubleshooting steps work, you may need to contact a professional to diagnose and repair the issue with your Toshiba Strata CHSU40A3 phone system.
3/2/2023 5:37:06 PM •
Toshiba...
Answered
on Mar 02, 2023
What happened when Toshiba laptop shows alt+ctrl+del?
More commonly called 'control alt delete' or the 'three finger salute' it has two purposes. On a computer that is running, it brings up Task Manager and other instant settings like Switch User, or log Out. On a computer that is frozen, unresponsive, it does a hard rest and forces the computer to reboot.
2/22/2023 11:34:41 PM •
Toshiba...
Answered
on Feb 22, 2023
