20 Most Recent Eaton Powerware FERRUPS® FE3.1kVA UPS System Questions & Answers
What type of batteries and
The manufacturers replacement part number for the battery is: 153302035-001
You could also try searching for the following: UPS12-270FR 12V 33Ah
12/27/2010 4:31:38 PM • Eaton Powerware... • Answered on Dec 27, 2010
Eaton 9130 showing Notice # 28 DC link voltage
Notice #28 on the Eaton 9130 indicates that the DC link voltage has exceeded the safe operating range. The DC link voltage is the voltage between the positive and negative terminals of the battery bank. It is important to keep the DC link voltage within the safe operating range to prevent damage to the UPS. The safe operating range for the DC link voltage on the Eaton 9130 is 280-450V. If the DC link voltage exceeds this range, the UPS will show Notice #28 and switch to bypass mode. This means that the UPS will no longer be able to provide power to the connected loads. There are a few things that can cause the DC link voltage to exceed the safe operating range. One possibility is that the battery bank is not properly charged. Another possibility is that there is a problem with the UPS itself. If you see Notice #28 on your Eaton 9130, you should first check the battery bank. Make sure that the batteries are properly charged and that there are no loose connections. If the batteries are properly charged and there are no loose connections, then you may need to have the UPS serviced. Here are some additional tips to help you troubleshoot the issue:
  • Check the battery voltage. The battery voltage should be between 28 and 45 volts.
  • Check the battery temperature. The battery temperature should be between 10 and 35 degrees Celsius.
  • Check the battery connections. Make sure that the battery connections are tight and that there are no corrosion.
  • If you have a multimeter, you can measure the DC link voltage directly.
If you have checked all of these things and the DC link voltage is still not within the safe operating range, then you will need to call a qualified technician to diagnose the problem.
7/8/2023 6:27:56 PM • Eaton Computers... • Answered on Jul 08, 2023
I have a new Eaton 9390 40kva when i want to start normally it go to bypass mode and give two alarm 1:alarm:configuration alarm 2:notice:ac output under voltage i need to solve it? THANKS
Because till u have alarm of configuration error in your system it won't accept the command it will always go into bypass u have to remove configuration error from ups system only then you are able to use ups system in online mode I can help u to fix it don't worry this is my WhatsApp number feel free to contact me Okk +919871039174
2/26/2023 7:58:33 PM • Eaton Computers... • Answered on Feb 26, 2023
My Powerware 9120 2000 has low power alarm and shutdown at 50% charge
A Powerware 9120 2000 is an uninterruptible power supply (UPS) device that provides power backup to connected devices in case of power outages or other power issues. If the UPS is shutting down at 50% charge and showing low power alarm, there could be several possible causes:
  1. The battery is failing: The UPS is designed to shut down when the battery charge reaches a certain level to prevent damage to the battery. If the battery is failing, it may not be holding a charge and may need to be replaced.
  2. The battery is not compatible: Make sure that the battery you are using is compatible with the Powerware 9120 2000 UPS. Using an incompatible battery can cause the UPS to shut down or display error messages.
  3. The battery cable is loose: Check the battery cable connections to ensure that they are tight and secure. A loose battery cable can cause the UPS to shut down or display error messages.
  4. The UPS is overheating: Check the UPS for any signs of overheating, such as a hot feeling on the top of the unit or a burning smell. An overheating UPS can cause the UPS to shut down or display error messages.
  5. The UPS firmware is outdated or corrupted: Check to ensure that the UPS firmware is up to date and not corrupted. Outdated or corrupted firmware can cause the UPS to shut down or display error messages.
If none of these solutions solve the problem, it's recommended to contact the manufacturer or a professional technician for further assistance. They will have the knowledge and expertise to troubleshoot and diagnose the issue with your Powerware 9120 2000 UPS.
1/13/2023 8:16:32 AM • Eaton Computers... • Answered on Jan 13, 2023
3answers
Eaton 9130 alarm 34 means what ?
the manual covers this, it tells you to read alarm event code messages they are not in number format but text. in clear english the alarms. RTM or call EATON, we are Fixya not EATON,ok> most error common means bad batteries. 99% are. http://www.eaton.com/content/dam/eaton/products/backup-power-ups-surge-it-power-distribution/backup-power-ups/eaton-9130-ups/eaton-9130-ups-pdm-user-guide-manual-164201798.pdf
8/18/2022 11:04:18 PM • Eaton Computers... • Answered on Aug 18, 2022
2answers
I have eaton 9130 ups it is password protected and i forgot password.
see the instruction booklet for that - - - or contact eaton directly.
3/9/2022 9:14:04 PM • Eaton Computers... • Answered on Mar 09, 2022
Why can't you just answer the question? Please don't refer me to a page in the manual that doesn't actually answer the question! The question is... I do not have the password to my Eaton 9130 bups. This unit was given to me by a friend,and no he doesn't remember the password, He is no longer with us. How do I reset the password for this unit?? Perhaps I'm not asking the right question?? How much money do you want to tell us how to reset the factory password???
Posted by Eugene Loach on Dec 08, 2019 Eugene you are very confused, 1: we are not Eaton ! nor any other non fixya website. 2: and is a free help site, GENERIC HELPERS, ( be happy?for free) 3: the tool is supported by the maker only. 4:further more password resets are protected by laws now. both not covered in book and by laws stating not to disclose these methods , to hackers and or thieves, ( 21st century stuff) the new laws in effect dictate to many makers, this, the new or original owner must prove they own it. then they send you the cure. now what is a BUPS, is that a typo, for UPSJust the UPS (but Back UP USP is what it is) not the communication port card. right? and uninterruptible Power system A.C, (I have one here) there are 2 Password levels stated in the manual USERS and service mode. the manual does not cover your topic, that is correct. now you know why.. the factory setting for Password, if not altered (page31) is "USER" beyond that, contact EATON, for 10x better answers. most users of any UPS do not change the password.home users? don't they just use the default ("USER") and is covered in the manual page 31. herehttps://www.eaton.com/us/en-us/support/backup-power-ups-surge-it-power-distribution/contact-me-eaton-9130-ups.html
12/8/2019 1:33:08 PM • Eaton Computers... • Answered on Dec 08, 2019
2answers
What is the meaning in eaton ups, error code 192
UPS used lead acid batteries which die after 3 or 4 years. Disconnect the power and open it to see which ones it uses. You will know they are dead if they have swollen or melted. Buy replacement batteries.
12/8/2019 12:38:04 PM • Eaton Computers... • Answered on Dec 08, 2019
My eaton 5110 was activated when our local power went down. Now, when turning it back on it beeps constantly, every 1/2 second, even with nothing plugged into it.
learn that when you have black out. the batteries TAKE OVER< and are huge stress on any battery like this,, and when the lights (AC power) turned the UPS tries to charge said batteries and are now bad. time for new batteries, or let it beep for 24hours and hope the batteries can recover. the manual tells you how to see if the batteries are bad and with errorcodes, on all UPS made. RTM read the manual first. no 2 UPS are the same , unless are. the first is battery voltage under charge, if too low that means a cell in 1 battery is shorted. as the LOVE TO DO.
12/8/2019 12:34:32 PM • Eaton Computers... • Answered on Dec 08, 2019
My eaton ups shows min charger voltage
no UPS stated, model. how old are you batterie(s) charging errors of most kinds means the battery is bad. they can do that even year old, but mine last about 3 years on avg. no battery in any USB with Gel Cells, last a long time. a fraction of all else inside the box. in fact. buy a new battery and put it in.
12/8/2019 12:31:17 PM • Eaton Computers... • Answered on Dec 08, 2019
Error 194 in eaton ups
contact eaton
7/5/2018 6:00:12 AM • Eaton Computers... • Answered on Jul 05, 2018
Alarm 707 in pulsar UPS
alarm 707 pulsar
6/22/2018 8:41:37 AM • Eaton Computers... • Answered on Jun 22, 2018
Eaton Powerware FERRUPS® FE3.1kVA  UPS System Logo
1 questions posted
Top Eaton Computers & Internet Experts
Ngoro
NOEL
NOEL
Are you an Eaton Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Eaton Computers & Internet
Most Popular Question
type batteries
  • Computers & Internet
