20 Most Recent
Lenovo IBM ThinkCentre® A55 PC Desktop Questions & Answers
No funciona el sonido quien puede ayudarme porfavor
por favor, vaya a Microsoft sitio web. descargar el Service Pack 2 o 3 para el Windows XP PRO.a continuación, instalar el equipo. si hay problemas se producen envíeme un correo electrónico: [email protected]
Esperamos que el traductor es correcta.
please go to microsoft website. download the service pack 2 or 3 for your windows XP pro. then install it your computer. if there are problems occur email me: [email protected]
hope the translator is correct.
2 time motheboard change for what resion
If the computer is working you don;t have to change
However if your sure it needs to be changed there are many reasons it could happen. Most likely is electro static discharge or ESD a static electricity shock from your finger can ruin a pc component if touched.
Auto processing
The auto processing is the monitor trying to adjust to a particular resolution. To help you control display quality, please follow the steps given below:
-Open the 'Display Quality troubleshooter' by clicking the Start button, and then clicking 'Control Panel'.
-In the search box, type 'troubleshooter', and then click 'Troubleshooting'.
-In the left pane, click 'View all', and then click 'Display Quality'.
GuruAid.com
3/21/2016 7:05:57 AM •
Lenovo...
Answered
on Mar 21, 2016
I am having a Problem with my video card not letting me run an addition monitor off the vga output on the motherboard. I know it works because I can go to the bios and change it and it works but they
When using a PCI or PCI-E graphics card, it will disable your standard VGA output port because the up-dated graphics card and your factory VGA port require different display drivers. Usually, the drivers are conflicting and will make your system unstable and cause it to crash. In short, you can't use both at the same time. I have a Radeon HD 5450 graphics card installed on my PC and it too has disabled my standard VGA port. If you are trying to use more than one monitor, you have to install a graphics card that supports a multiple display output. The graphics card will either have 2 VGA ports, 2 DVI-D ports or 2 HDMI ports or even any combination of the 3. My card, for example, has 1 VGA, 1 DVI-D & 1 HDMI. I can run up to 3 monitors at a time via my graphics card, but I cannot run a 4th monitor from my factory VGA port. My graphics card uses ATI/AMD drivers while my VGA port requires the use of Nvidia drivers.
I hope that you find this useful.
4/5/2015 9:37:26 PM •
Lenovo...
Answered
on Apr 05, 2015
