20 Most Recent HP PhotoSmart C4385 All-in-One Printer Questions & Answers
Reset Hp C4385 All in one printer to new ATT 2Wire router?????
Turn on your Wireless printer. You can use the touchscreen in the wireless printerto connect your wireless network. On the touchscreen, press the right arrow key and press setup. Select Wireless Setup Wizard from Network menu, it will search for the wireless routers in the range.
2/22/2018 4:08:26 PM • HP PhotoSmart... • Answered on Feb 22, 2018
I can't scan, message showing
Hello and Welcome to FixYa!
This error may occur due to many reasons, It will be difficult to state all of them here with possible solutions, so a better option is to Diagnose everything with the help of HP's Scan Diagnostic utility. I've attached the download link below, you have to select your operating System from the drop down menu above, then expand the Utility Link, and Download the Scan Diagnostic Utility.
I hope this will solve your issue.
If you think I was of help, your token of appreciation in the form of rating will be esteemed.
Concerned, Nooh
P.S: Download Link
2/1/2014 10:33:22 PM • HP PhotoSmart... • Answered on Feb 01, 2014
0answers
I continually get a fatal error at 96% during
Try using a another installation cd hope it helps
12/9/2013 2:12:05 PM • HP PhotoSmart... • Answered on Dec 09, 2013
Uninstall
On Windows OS: go to "control panel" then to "Add/Remove Programs". Find the printer software then click uninstall button
7/2/2013 4:33:48 AM • HP PhotoSmart... • Answered on Jul 02, 2013
My hp photosmart c4385 all-in-one is not printing, its asking for IPadress and email, pls i need ipaddress
that IP it unique for your printer , just like your ID number , so can identify printer for other computers , so get it form your network or tell I.T engineer so can gave you ip address , hope help you Mohamed Hejazi Afaqnama - Libya [email protected]
3/21/2013 6:50:49 PM • HP PhotoSmart... • Answered on Mar 21, 2013
Cannot power up
Logic Card Problem.
1/4/2013 4:11:57 PM • HP PhotoSmart... • Answered on Jan 04, 2013
Print cartridge(s) missing or not detected
Hi,If you are getting Incompatible ink cartridge error and These cartridges were replaced a year ago, I think its time you call them once again. ( 1-800-474-6836 ) and report the issue. They will ask you for the Cartridge details like part # and expiry date on the cartridge. Regards,Sean
12/24/2012 8:17:16 PM • HP PhotoSmart... • Answered on Dec 24, 2012
My hp photosmart c4385 all in one says the ink cartridge is not in but they both are
Try to take out cartridges and check the chip. Maybe it is grimy. Clear it with cotton buds soaked with ethyl alcohol or vodka or some strong alcohol. Clear also the connectors in the printer.Put the cartridges back. Good luck.
8/21/2012 8:28:57 AM • HP PhotoSmart... • Answered on Aug 21, 2012
2answers
I cannot get scanning to work on my mac. I can
You should be able to get the driver from here, reinstalling the driver should correct the situation
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=219&lc=en&cc=sg&dlc=en&sw_lang=&product=3651156#N631
Hope this helps
8/1/2012 7:57:57 PM • HP PhotoSmart... • Answered on Aug 01, 2012
2answers
White lines across my scanned images
I had the exact same problem! the problem seems to be with the CCD calibrating itself before it starts to scan.If you look into the scanner, the scanner glass extends itself into the casing of scanner where the CCD rests. Every time before the scan starts the CCD starts to calibrate itself in its housing before it starts to scan. If there is any reminiscence of dust or anything object (like a piece of paper) stuck in the edges where the CCD rest, the white balancing is thrown off and it causes white lines to appear along the entire line where the dust was present.Ideally the solution would be to open the scanner casing to clean the housing where the scanner CCD rest. This would solve the problem.If you are unable to open the scanner casing, then try using a piece of paper or a thin edge of a cloth, slightly dampened to reach into the edge of the scanner glass where the CDD rests and clean it. This is what i did and this solved the problem.
7/24/2012 5:47:09 AM • HP PhotoSmart... • Answered on Jul 24, 2012
HP PhotoSmart C4385 All-in-One Printer Logo
159 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
PhotoSmart HP
  • PhotoSmart HP
Most Popular Question
print cartridge s missing or not
  • Office Equipment & Supplies
