20 Most Recent Canon Pixma iP2600 Photo InkJet Printer Questions & Answers
9answers
Canon ip 2600 printer. Paper does not feed
Hey I had the same problem. Called the company; we couldn't fix it. Well I turned it upside down and a 2" flower stem fell out from when I cut some flowers next to my desk. It still didn't work. I was examining the feed area while it was running and I found another little piece of stem that was lodged way in there. I had to get it out with tweasers and it turned out to be 1" long. Couldn't really see it at all. Works fine now.
12/1/2021 12:00:17 PM • Canon Pixma... • Answered on Dec 01, 2021
2answers
Both lights are blinking and will not print
they call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
5/24/2019 9:34:07 AM • Canon Pixma... • Answered on May 24, 2019
2answers
My canon printer wont print
Issues with the cartridge are other causes for trouble in your printer. If you have not used your printer for a pretty long time, there's chance for the ink in the cartridge to get solidified, ending up in its damage. The issue could also be caused due to the lack of ink in the cartridges. In order to resolve the issue, you might ensure that you are not keeping your printer idle for very long periods. You could also check its ink level.
4/3/2019 11:12:44 AM • Canon Pixma... • Answered on Apr 03, 2019
5answers
Printer keeps on jamming paper
Dear all,
I will try to help you. Paper jam error may be caused by some possibilities. So, please notice this indication:
  • If the printer status is READY immediately after Power ON then Paper Jam Error message appears while feeding the paper: Sheet Feeder Unit is faulty or any other material (such as broken paper) present inside paper path blocking paper end to reach paper feed sensor.
  • If Paper Jam Error messages appears immediately after Power ON: Paper feed sensor or logic board is faulty
Corrective action:
  • Remove the material from paper path
  • Replace Sheet Feeder Unit
  • Replace Paper Feed Sensor / Logic Board
Please rate me as Fixya if you find this useful for you. Thanks.
Source:
Canon Inkjet Printer Forum
Re
12/1/2018 5:43:59 PM • Canon Pixma... • Answered on Dec 01, 2018
2answers
Ink reservoir full
Heres a canon link for finding your nearest service centre http://www.canon-europe.com/Support/Consumer_Products/services_locator/index.aspx However, you may want to review the following links - which explain how to do the cleaning yourself Theres a number of solutions on this link http://www.fixya.com/support/t181480-waste_ink_absorber_canon_ip_1600 This is not your exact model - but maybe useful to watch http://www.youtube.com/watch?v=VVpjqBr7KjU http://www.youtube.com/watch?v=4IrBdw7el2E Theres some instructions on this post on how to clean http://www.fixyourownprinter.com/forums/printer/41279 But Beware of causing any damage
12/1/2018 11:24:29 AM • Canon Pixma... • Answered on Dec 01, 2018
Printer does not recognize cartridge
could be a faulty ink cartidge.. try a different one if you have a spare... or even put the old one in, and see if the mesage changes to empty cartridge,,,
4/19/2017 6:44:51 PM • Canon Pixma... • Answered on Apr 19, 2017
Canon iP2600 how to print test page without computer
http://www.manualsprinter.com/manuals/canon/Canon_PIXMA_iP2600.pdf .found this manul not sure if it will help you out.
11/26/2016 5:42:37 PM • Canon Pixma... • Answered on Nov 26, 2016
Paper jams on one side
If you wish to get some details about printers an copiers error codes and repair ; check the site linked here. Pull up older posts... http://electro-medical.blogspot.com/
5/21/2016 7:50:46 PM • Canon Pixma... • Answered on May 21, 2016
Why are pages coming out striped?
There is probably dirt on the rollers or on the paper carrier. You could try running the printer through a self clean first. Go into the printer settings, menu, locate self cleaning and press that.
9/18/2015 3:10:32 AM • Canon Pixma... • Answered on Sep 18, 2015
Ink absorber is full
The absorber needs to replaced in a shop. # QY5-0240-000, A shop needs to do it because they have the software to reset the error, after the absorber is replaced.
5/12/2015 9:35:00 PM • Canon Pixma... • Answered on May 12, 2015
THE PAPER COMES OUT BLANK WITHOUT PRINTING.
Make sure you remove the protective tape from cartridge(s). If it's been removed, try running 'nozzle clean' or 'deep clean' (for that cartridge). You can find this in 'Printer properties' on 'Maintenance' page.
3/2/2015 11:48:04 PM • Canon Pixma... • Answered on Mar 02, 2015
How do I fix my ink cartlidge when it is stuck on the right side?
If catridge is in reach of your fingers then pull it back otherwise you have to open the chasis screw of the printer and pull out upper cover and rotate the belt and you can then make printer workable
7/23/2014 4:17:14 AM • Canon Pixma... • Answered on Jul 23, 2014
2answers
Printer wont print
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
7/14/2014 5:25:13 PM • Canon Pixma... • Answered on Jul 14, 2014
Canon Pixma iP2600 Photo InkJet Printer Logo
405 questions posted
old marine
old marine
ZJ Limited
ZJ Limited
View Most Popular
PIXMA Canon
  • PIXMA Canon
Most Popular Question
canon ip 2600 printer paper not feed
  • Office Equipment & Supplies
