20 Most Recent Canon PIXMA MP210 InkJet Printer Questions & Answers
Printer is not working
The Pixma MP210 does not support a wireless connection. It has a USB port. Some wireless routers do have USB ports and can thus share the printer. Similarly, there are print server options that can be connected to the USB port. However, these will not work with the scanner functions of the all-in-one. Also you would need to confirm that the print server you choose is compatible with the Pixma MP210. The fastest way to print right now is to connect the USB cord to the laptop. Wait for the drivers to be installed and then send the file to the printer. Moving the cable will let both computers use the scanner features of the all-in-one. A manual USB A/B switch might allow you to share the printer with fewer chances for a damaged USB cable. However, these usually don't support the scanner. Scanning requires bi-directional communication between the printer and the computer. A bad USB cable can turn an all-in-one into a single function printer with a direct USB connection. Once the MP210 driver is on both systems and they are connected to the same network, you may be able to set up the desktop as a print server for the laptop. This will depend on the OS on both systems. Something like the Windows Homegroup easily allows printer sharing when enabled for systems with Windows 7 and newer on a private network. Both systems need to join the same homegroup. One system starts the homegroup. Then you have to type in the password on the second computer. This works even with one system connected to the wireless network and the other connected to a wired port on the router. On Vista and XP, you could enable printer sharing as well in the Network and Sharing center. See https://www.wikihow.com/Share-a-Printer for the steps With Windows OS versions, the scanner functions will only be available on the computer with the direct USB connection. I hope this helps. Please add a comment with the OS versions on both the desktop and the laptop if you need more specific advice. Cindy Wells
12/23/2017 12:08:20 AM • Canon PIXMA... • Answered on Dec 23, 2017
Why can't the printer start up?
Replace the cord. Also check the wall socket with a multi-meter. Try different wall socket.
3/30/2015 1:39:31 AM • Canon PIXMA... • Answered on Mar 30, 2015
2answers
I have mp210 and want
1. In Windows: Go to Start>Devices and Printers>Right click on your default printer. Select printing preferences.
2. In the area that reads: Additional Features in the middle of the window, you'll see a selection that reads: Grayscale Printing Put a check in that box. This will print everything in black and white.
3. Go down to the bottom of that window and put a check on the box that reads: Always print with Current Settings.
4. Click Apply
5. Click OK.
Once you are just printing in black and white, the only cartridge you will have to replace is black ink-unless you change it back to color in the future-then you will have to replace the color cartridge as well when it is low.
12/4/2014 1:28:53 PM • Canon PIXMA... • Answered on Dec 04, 2014
2answers
If the black ink runs
Hi. When you are printing in black but "black and white" is not selected in the printer "properties", the printer will use some of your colored ink to print grays. If the black ink goes out, it will give you an error and will not print using colored ink even if you are printing black only. Hope this helps.
12/4/2014 1:19:00 PM • Canon PIXMA... • Answered on Dec 04, 2014
MP210 erreor how do i fix my printer when it flashse E1 and E4
Canon gives this answer: 31480a7d-b0f3-4839-bf96-8314e8d8a4e4.png You could have googled it yourself, saving lots of time. Google answers within a second, Canon takes about 3 seconds.
7/16/2014 8:55:09 AM • Canon PIXMA... • Answered on Jul 16, 2014
0answers
2answers
The printer has been sitting
Hello hol0,
If the printer has not been used the ink cartridge may be dried/clogged. This happens when ink does not flow for long periods of time. The cartridge may be full of ink (therefore, not giving low ink level warnings) but unable to flow due to clogged pathways. Try a new ink cartridge and that should fix your problem!
Hope this helps!
12/13/2012 10:30:52 AM • Canon PIXMA... • Answered on Dec 13, 2012
0answers
How do I scan on Canon MP210 Printer
hi,
  • Turn off the printer.
  • Install the software that came with the printer.The MP navigator EX program.
  • Open this program[navigator EX program].
  • Turn on the printer.
  • Insert the documents you want to scan into the document feeder.
  • Press scan on the printer.
  • The documents will scan into the navigator program.
Thanks!
9/25/2011 8:33:06 PM • Canon PIXMA... • Answered on Sep 25, 2011
3answers
I NEED MANUAL FOR SCANING
Hello daisy0562,
I have a "direct link" for you, to "Download the Manual,"
for the {Canon PIXMA MP210}.
If you need help, with anything else?
Write a 'comment', I'll be standing by to assist you!
"Best Regards"
Click on the 'link' below, for the "Manual" http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp210#BrochuresAndManuals
9/15/2011 12:12:58 PM • Canon PIXMA... • Answered on Sep 15, 2011
I lost the manual for
Go to this link, click Guides & Manuals in section Brochures & Manuals and downloadMP210 series On-screen Manual. Install it and then double clickMP210 series On-screen Manual shortcut on your desktop. There you'll find scanning guide.
If this helped you, please rate my answer :)
9/6/2011 2:51:50 PM • Canon PIXMA... • Answered on Sep 06, 2011
How do I scan docs
Open Solution menu from your desktop and choose Scanning Photos. Now put you photo on scanner board and press preview from your solution menu. After preview completing press scan... thanks
8/27/2011 5:11:05 AM • Canon PIXMA... • Answered on Aug 27, 2011
0answers
0answers
Canon PIXMA MP210 InkJet Printer Logo
147 questions posted
old marine
old marine
ZJ Limited
ZJ Limited
View Most Popular
PIXMA Canon
  • PIXMA Canon
Most Popular Question
canon mp210
  • Office Equipment & Supplies
