20 Most Recent Activision Guitar Hero Wireless Les Paul Guitar for PlayStation 3 Questions & Answers
PS2 and guitat hero wireless guitar controller not in sync
Not for that system?
10/22/2013 4:35:22 AM • Activision... • Answered on Oct 22, 2013
Guitar and ps3 wiil not sync please help
Is it on the right system?
10/22/2013 4:30:18 AM • Activision... • Answered on Oct 22, 2013
0answers
0answers
I have a les paul
Hello there,
First you need to know that the guiter hero 3 comes with a wireless dongle on it. It is most times attached to the bottom of the guiter hero 3. Slide it off the guiter and connect it to your playstation 3, a light will flash on the dongle. Then you press the PS button on the guiter 2 times and it will connect.
This could take a while for you to get it but most times it takes two taps on the button.
There are other ways to try such as:
  1. If you play Guitar Hero III on PlayStation 3, you'll get a wireless controller, but it doesn't work seamlessly with PS3's built-in Bluetooth. You'll have to plug a dongle into the USB port on your console.
  2. if you're going to have a dongle hanging there, you may as well make it pretty. Guitar Hero's is shaped like a guitar pick.
  3. The dongles have sync buttons on them, so you can just tap the button on your controller, then on the dongle to sync them up - perfect if you have more than one controller.
Here is another way to connect you guiter hero 3 to your playstation 3.
Do the following to connect and sync your guitar to the Playstation 3.
Connect the wireless dongle to one of the USB ports on the front of the system.
If there is a solid red light on the dongle check your guitar for a red indicator light. If there is a light you are finished.
If there is no light or the light is flashing press in the small button on the front of the dongle
A red light will flash on the dongle and the position indicator lights will flash above the guitar's strum bar
Press in the PS button on the guitar, the red lights above the strum bar will stop flashing and only one red light will remain illuminated. It may take several seconds after hitting the PS button for the flashing to stop. If it is taking longer than a few seconds and the lights are still flashing press the PS button again, you may need to hit the PS button several times.
If all of the lights flash and then go out do the following. Move or turn off anything near the PS3 that uses a wireless transmitter (this includes cordless phones and other non PS3 wireless controllers). If your PS3 is inside an entertainment center please remove it and try to sync the guitar again. Large metal objects near the wireless transmitter can also interfere with the signal. You should also vary your distance to the console, if you are far away come a little closer, if you are close move back. We have seen people being to close in particular cause issues during the syncing process.
If any of this does not work, then you will have to take it back to the dealer that supplied it to you. It should still be under warranty.
All the best. Elect_Comp
9/11/2011 7:37:18 AM • Activision... • Answered on Sep 11, 2011
I've tried everywhere to find a solution to this
Turn the PlayStation 3 on and start the game.
On the dongle (while it's plugged in) press the button, then on the guitar look for a small pin hole, press a paperclip into it and hold for three seconds. And then press the PS button on the guitar.
That should take care of that!
2/28/2011 5:13:11 AM • Activision... • Answered on Feb 28, 2011
0answers
Mi Guitarra Les Paul de
necitas a synchronizazado el guitarra.
1.planane un boton en frente de la caja serca de la SD card slot
-planane este boton por dos segundos
2.despues planane otro boton chico que puedes ayare a bajo de la guitara(la cola de la guitara)
planane por 2 secundos tambien...
y con eso tu problema se va (perdon soy americano...pocito espanol..)
1/4/2011 1:51:17 AM • Activision... • Answered on Jan 04, 2011
0answers
Les paul guitar compatible with world tour ps3
Make Sure That Your Guitar Is Not A Third Party Accessory.
4/21/2010 11:31:46 AM • Activision... • Answered on Apr 21, 2010
How do i connect my les paul wireless guitar to my
1. First of all, make sure the batteries are in the guitar.
2. With your PlayStation 3 console powered off, insert the wireless receiver into an available USB connector on the console.
3. Press and hold the PS button on the guitar to turn it on.
4. Turn on your PlayStation 3 console.
5. Press the connect button on the wireless receiver (not the guitar). The status light will flash, indicating that the receiver is searching for the controller.
6. Press the PS button on the guitar to establish a connection with the receiver. (You may have to wait for the receiver to stop flashing so fast. I think it flashes real fast at first, but then slows down.)
Also, make sure the guitar is assigned as control port #1.
I hope that helps.
Another thing that may help. Unplug all your usb cords that recharge your headset or controllers. Make sure the USB connector is the only thing pluged in and in the furthest left slot. That is what i had to do.
3/24/2010 7:06:14 PM • Activision... • Answered on Mar 24, 2010
I cant connect my guitar to the ps3
I hope that helps.
3/24/2010 7:04:55 PM • Activision... • Answered on Mar 24, 2010
How do you sync a guitar hero guitar to a ps3?
so try this and i hope it works!!
try:
1.turning off guitar,plug in adaptor to system,turn on guitar
2. change out the batteries (and check if batteries are secure.)
i hope i helped let me know how it works
1/8/2010 1:36:23 AM • Activision... • Answered on Jan 08, 2010
Is Guitar Hero III Legends
try these... have it downloaded and burn it using nero or any burning software to a dual side dvd..
guitar hero!! download
SYSTEM: PS2 GAME TYPE: NTSC version USA SIZE: 7.94Gig uncompressed 4.94Gig 8 x 700Mbs Compressed **EDIT ON THIS PART*** WORKS ON: HDLoader .8c =(modes 1 + 3 may be needed) Duel Layer DVD+/-R =(Burn with any app./Nero) **AS FOR ESR** if you have problems with not reading from second layer with ESR r9b, patch it with Toxic Dual Layer patcher and then ESR, works best with ESR r9a Direct.elf ***Nobody has had success with Swap Magic 3.6, but 3.8 they have*** try Swap magic 3.6 at OWN RISK For info on how to burn or make backup copy's of PS2 games work please search google.. BONUS: I have also included the Manual as well as the DVD Pix Image as well as the cover art.. (The scans are subpare at best. I was in a hurry-sorry) For my other listings as well as help.. Please visit: Later, Civic !!PLEASE SEED & ENJOY!! SEEDSEEDSEEDSEEDSEEDSEEDSEEDSEEDSEEDSEED SEEDSEEDSEEDSEEDSEEDSEEDSEEDSEEDSEEDSEED SEEDSEEDSEEDSEEDSEEDSEEDSEEDSEEDSEEDSEED SEEDSEEDSEEDSEEDSEEDSEEDSEEDSEEDSEEDSEED IF YOU ARE DOWNLOADING THIS SEED AT LEAST 200%!!!!!!! PLEASE!!! PEOPLE AREN'T GOING TO GET THIS SOON IF YOU KEEP LEECHING!!! 800+ leechers, and Civic(the provider) is the only one seeding!!! HOW IS THIS?!?! ARE PEOPLE REALLY THAT GREEDY? WE SEED FOR YOU!!! WHY NOT SEED FOR OTHER PEOPLE?!?! SO WHEN YOUR DOWNLOAD IS DONE, SEED SEED SEED SEED SEED!!!! ***EDIT******EDIT******EDIT******EDIT******EDIT******EDIT******EDIT*** for more info and the original location of this torrent, and need further help go to www (dot) mininova (dot) org/com/1922742 ^^ ^^ period here period here **ALL THANKS GOES TO CIVIC** for some further help go to Civic/Scooter's thread on PSX Scene http://psx-scene.com/forums/ps2-game-backup/59531-scooter-guitar-hero-world-tour-civic.html (have to register to access the forum) ***DVD5******DVD5******DVD5******DVD5******DVD5******DVD5******DVD5******DVD5*** DVD5******DVD5******DVD5******DVD5******DVD5******DVD5******DVD5******DVD5******DVD ***DVD5******DVD5******DVD5******DVD5******DVD5******DVD5******DVD5******DVD5******DVD5******DVD5******DVD5******DVD5******DVD5******DVD5******DVD5******DVD5******DVD THE DVD5 RIPKIT IS FINALLY HERE!!!!!!!! psychospacefish has compiled this ripkit literally 2 hours before me posting it in this description. you can get the ripkit here http://www.alucard.cc/forums/index.php?action=dlattach;topic=2084.0;attach=1337 Media: DVD-5 (4.36GB) Complete Ripping information: All but 3 Stages were ripped, rest are relinked In songs 33075HZ stereo ADPCM was downsampled to 27000Hz stereo ADPCM, and 16538HZ mono ADPCM was downsampled to 13500Hz mono ADPCM INSTRUCTIONS FOR RIPKIT: 1.Extract from an ISO image all the files from both layers with Apache 2 or 3 into the same folder as the ripkit (you can delete the ISO after this) 2.Run ghwtrip.bat 4.At the end IML2ISO will pop up, select ghwt.iml and click start. 5.Burn the ISO at 4X with DVD Decrypter. Big thanks to gnie for his Xpert2 tool, and DVDIML2ISO. Thanks to neness for Kit Magician. Thanks to GameZelda of scorehero.com for HEDTools. Thanks to muzzleflash for MFAudio. once again thank psychospacefish from psx-scene for making this ripkit, and its only 3 days after it's release =O show your support to psychospacefish and make a donation: https://www.paypal.com/cgi-bin/webscr?cmd=_xclick&business=modawg%2emoen%40gmail%2ecom&no_shipping=0&no_note=1&tax=0¤cy_code=USD&lc=NZ&bn=PP%2dDonationsBF&charset=UTF%2d8
12/9/2009 3:06:05 AM • Activision... • Answered on Dec 09, 2009
2answers
When i press the ps3 connect button on the quitar
if its brand new u need to register it on the PS3
10/17/2009 12:10:48 AM • Activision... • Answered on Oct 17, 2009
XBOX 360 wireless guitar doesnt connect to system & dont know why
Power on your Xbox console and allow it to load to the Xbox dashboard.
Press the green Xbox controller on the guitar. All four lights surrounding the button should start flashing.
Press the connect button on your Xbox console (It's next to the Memory Card #2 slot).
Press the wireless button on the "Guitar Hero 3" guitar (Look for the on the bottom of the guitar).
Wait for the four lights to stop flashing, with one light becoming a solid green. Your air guitar should now be connected remotely to the Xbox.
8/28/2009 10:20:41 PM • Activision... • Answered on Aug 28, 2009
All intruments and wireless dongles turned on and
I only have the guitar version but... on the PS3 menu (not inside the game) go to settings --> change controller number (or words to that effect) and change the controller number of the guitar.
8/7/2009 12:40:11 AM • Activision... • Answered on Aug 07, 2009
2answers
Drum, guitar and mic for Guitar Hero World Tour PS3
using the guitar, outside of the game go to settings (and this is from memory so forgive me if it's not 100% accurate) and then controller settings and assign controller number... change it to a lower number. I chose 1. Problem solved.
8/6/2009 10:07:15 PM • Activision... • Answered on Aug 06, 2009
Activision Guitar Hero Wireless Les Paul Guitar for PlayStation 3 Logo
52 questions posted
Top Activision Video Game Consoles & Games Experts
Sean Wright
Sean Wright
MegaByteMe
MegaByteMe
john h
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
View Most Popular
  • Activision Video Game Consoles & Games
Most Popular Question
guitar ps3 wiil not sync please help
  • Video Game Consoles & Games
