20 Most Recent
Educational Insights Classroom Jeopardy! Questions & Answers
I have been using Classroom
Hello.
I'm not certain this answers your question, but Each accessory scoreboard (ASB) comes with one black Power Cord and one white Signal Cable. Plug one end of the Power Cord into the ASB and the other end into the Base Unit. (The receptacles are
located on the left-hand side of each unit.)
Insert one end of the Signal Cable into the Base Unit port marked SIGNAL OUT. Insert the other end into the ASB port marked SIGNAL IN.
If you are trying to replace the Signal Cable with another cable, I would suggest taking the cable to a local shop, such as Radio Shack and match the cable.
You may already know the set up, but this also could help:
The back of each Accessory Scoreboard has a 4-position switch. The switch is used to set the code from the Base Unit so that the Player Remotes can be assigned to the
corresponding scoreboards.
Set the ASB switch as follows:
Switch Positions
ASB Player No. 1 2 3 4
1-3* OFF OFF OFF OFF * (Players 1-3 are default to the Base Unit)
4-6 OFF OFF OFF ON 2nd scoreboard
Hope this helps.
Will 83069-U18 controller work on a PS2 please?
The Nyko Core Controller 83069 is a versatile controller that is compatible with both PCs and PlayStation 3 consoles1. However, there is no specific information available about its compatibility with a PlayStation 2 (PS2). It's always a good idea to check the product's user manual or contact the manufacturer for the most accurate information.
If you have a PS3 or a PC, you should be able to use this controller. Please note that compatibility can sometimes depend on the specific model of the console and the controller's firmware version
What does code 71 on a 2013 paccar 587 mean?
Its when the Shift attempts to pull out of gear, but the Gear Position Sensor indicates that the transmission was unable to disengage that gear. and detected a system failure, and unable to detect the cause.
Solitaire Customer Service Call 1-8O5-225-6690
We are 24 Hour Available Call Now
Well you really didn't loose them.
What happens is Hp puts in the software of a whole bunch of games where after time you have to go to their site and purchase their games.
Well there are other FREE sites to goto to find Solitaire, free cell, Spyder solitaire and such.
I also think that they meybe hidden files in Windows, but to find them you have to remove Hp games and then do a search
