20 Most Recent
Polk Audio PA250.2 Car Audio Amplifier Questions & Answers
5channel amp 6 speakers how
if it is a 5.1 channel amp wire the center speakers together into the same port. wire the two front speakers in the or der that they would appear on the amp (such as left front speaker to the left front speaker terminal on the amp etc.) and do the same for the rear speakers. and all you should have left is the sub-woofer channel in which you do not have to worry about.
Whats the rateing on the polk 10 inch sub woofer
Hello dread2477,
The Polk Audio db1040 is a single voice coil 4ohm subwoofer. The db1040DVC is dual voice coil with 4ohm coils which can be wired in parallel for a 2ohm load, or in series for an 8ohm load. They are practically the same sub. The RMS power range is 50-270 watts, with a maximum peak power of 540 watts.
The full specifications including recommended enclosures and physical dimensions can be found
here.
Hope this helps.
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
