20 Most Recent
MTX Terminator TN400/4 Car Audio Amplifier Questions & Answers
I just replaced my old
You may have touching speaker leads going into the amp. Make sure the tinsel is not touching across the speaker inputs on the amp. Also check your ground. It should be solidly connected to the vehicle chassis in a paint-free location. Finally, make sure there are no exposed speaker wires touching the vehicle chassis.
Amp wasplaying red light came on and won't go away
The red light is a power protection circuit designed to shut the amplifier down due to an overload or wiring problem. If the amp was playing then shut off, my guess is a problem with the speakers or the speaker wiring. Some amplifiers are only stable to a certain load. For example, most car audio speakers are 4 ohms which is the resistance placed upon your amplifier to produce a certain volume of sound. If you bridge two 4 ohm speakers together in parallel, you cut the resistance in half, thus increasing the amount of power (and volume) to your speakers. This also creates more heat and could, in effect, shut your amplifier down. I would find out how the speakers are wired to determine the resistance of the load your amplifier is pushing.
My light on my amp is red
that means that your amp is in protection mode, check all your wires and also the speaker configuration.
