20 Most Recent
Samsung LN40A550 LCD TV Questions & Answers
"Service not supported" with Internet@TV.
Problem persists :
------------ ----------- ---I have configured the network in the samsung 40" LCD TV, using Ethernet cable to a router. The ping test, DNS server, GW Tests are passing ok. I am able to ping to the IP address of the samsung TV from my Laptop. My internet browsing via the service provider Airtel is otherwise working excellent with Laptop (Vista) or MacBook.
Router : 192.168.0.1
Laptop : 192.168.0.16
Samsung : 192.168.0.5
GW : 192.168.0.1
But Internet #TV gives "Service Not supported"
Any known issues?
Thanks,
Ilango
Netflix will not connect??
www.cnet.com > Forums > Samsung
CNETI have an un55es7150 i did all the updates for the TV as well as Netflix, and it works great ... In reply to: Samsung smart tv netflix problems. 1. .... I had tech test my internet connection and he said it was fine. ... I have a PN51d6500 smart LED tv.
www.samsung.com > Home > Support
Samsung ElectronicsVisit Samsung today for LN40A550. You'll find product and ... ALERT: Apps notLoading or Smart Hub not Loading Learn More. See More + ... Connect with us.
BN97-02472C issue
It doesn't seem to
Unfortunately capacitors have been projected as a cure to all possible problems in an LCD tv by some you tube experts. The actual problem may lie in the power board or the main board. An expert is needed to check and find the actual culprit.
What is the Samsung pairing code
There are many codes to check with. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
