20 Most Recent
Panasonic TC-32LX85 LCD TV Questions & Answers
My panasonic tv model TC32LX85 N has self check and wont go away?
To Exit Self-check Screen
- Press and Hold Power button on the TV for 5 seconds [or] disconnect the AC cord from wall socket.
TV volume down and OK on the remote only does a basic IC self check. It do not rest the TV. It do not clear channel programmed settings, picture settings, channel labels, lock settings or password. Using this method, it shows the units' firmware version [Peaks 1.050 and GenX 1.00] and it checks the IC communications only. This is more useful to identify the firmware version, without having to decode the info in the setup menu about version/screen.
TO RESET THE UNIT
- To make a reset to TV, turn it ON while pressing the [Volume-ve] button on the main unit, and press the 'Menu' button on the remote control for more than 3 seconds. The self check menu appear on the screen. Then disconnect the AC cord from the wall outlet. [ALL PROGRAMMED PARAMETERS WILL BE ERASED]
9/24/2017 9:16:37 PM •
Panasonic...
Answered
on Sep 24, 2017
Why wont my tv turn on
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Do asearch by type in the brand name of your device at its search box.
It will be best to replace the power supply regulator board as card basis.
7/24/2014 6:47:13 PM •
Panasonic...
Answered
on Jul 24, 2014
No picture light blinking
We recommend you remove all HDMI cables from the TV then unplug the unit's power cord for 30 seconds. Then plug the power cord directly into the wall. If the problem persists we recommend you have the TV evaluated by an authorized service center.
3/25/2014 2:22:22 PM •
Panasonic...
Answered
on Mar 25, 2014
Panasonic tc 32lx85 mounting screws sizes
Call Panasonic customer service and they will provide either the parts or the size and thread type----most of these bolts are common and can be purchased at Home depot etc.
10/30/2012 3:10:30 PM •
Panasonic...
Answered
on Oct 30, 2012
My t.v. has volume issues. Volume between
it is fixable the sound may depend upon the channels also but the antenne might not beeing catching signals properly so by changing the face of antenna u can remove this problem
4/1/2011 6:00:55 PM •
Panasonic...
Answered
on Apr 01, 2011
