20 Most Recent Kenwood Excelon KDC-X592 Car CD/ MP3 Player Questions & Answers
0answers
My bluetooth on my KDC-X592
Here is a link to the manual for your unit: https://www.manualslib.com/products/Kenwood-Kdc-X592-Excelon-Radio-Cd-12367.html
1/1/2018 6:53:12 PM • Kenwood Excelon... • Answered on Jan 01, 2018
2answers
I forgot the security code to my stereo
Call the Dealer!
3/19/2015 11:22:35 AM • Kenwood Excelon... • Answered on Mar 19, 2015
Where could i fond the wiring diagram for my Kenwood Excelon KDC-X592 Car CD/ MP3 Player?
There are vehicle - specific adapter plugs for after market radio hook ups. These adapters are used to connect the original plug that was connected to the original radio with the new radio's plug. You didn't list what vehicle you have, year, model. You can do a web search with " (year and model of vehicle) radio wiring adapter". Hopefully you'll find the adapter for your vehicle.
5/29/2014 2:55:25 PM • Kenwood Excelon... • Answered on May 29, 2014
2answers
I lost my security code
Have to contact authorized kenwood dealer, they have a universal code.
7/12/2012 12:25:04 PM • Kenwood Excelon... • Answered on Jul 12, 2012
Cd and usb just reading and not playing
get a new one
3/14/2010 12:44:57 AM • Kenwood Excelon... • Answered on Mar 14, 2010
Where can I download a free operating manual for a
Click here to download the user's guide.
9/7/2009 8:58:28 PM • Kenwood Excelon... • Answered on Sep 07, 2009
Installing a KDCX-592 in my son's 95 Nissan
get the "nissan to kenwood" factory converter harness available at best buy. but if you don't want to pay best buy prices, go to a local mega mall or swap-o-rama, and go to radio and sounds spot there
7/26/2009 9:47:54 PM • Kenwood Excelon... • Answered on Jul 26, 2009
The sound will cut out then come back on later on.
check make sure the radio wire at the back is plug in securely and all spker wire is not loose and touching the body of vehicle if you running an amp check wiring
6/26/2009 2:07:45 AM • Kenwood Excelon... • Answered on Jun 26, 2009
Changed car battery & Kenwood execolon kdc-X592 AUX is gone
Try pressing 'menu', scroll to "built in aux", and toggle to the 'on' position. Then the aux input should be available again. The radio losing power would have reset any internal memory causing it to go back to factory defalts. Hope this helps
1/30/2009 3:51:48 AM • Kenwood Excelon... • Answered on Jan 30, 2009
Security Code?
It is an anti-thieft feature so the radio becomes worthless if it is stolen from the car. If you take your car to the dealer they can reset the radio. You will usually only need the registration from the car. They will usually charge a standard fee so call around for the best deal. The work will take approx. 30 seconds.
1/30/2009 3:17:10 AM • Kenwood Excelon... • Answered on Jan 30, 2009
My kenwood kdc-u2159b display call n no sound out
Me radio kdc2159b is displaying the ward call,how do i remove it
4/14/2024 10:44:35 AM • Kenwood Car... • Answered on Apr 14, 2024
Reset a Kenwood 8070 without a remote?
To reset a Kenwood 8070 receiver without a remote, you typically need to locate the reset button on the device itself. This button is often small and recessed, so you may need a paperclip or a similar tool to press it. Consult the user manual or look for the reset button near the power or input/output ports on the receiver. Once located, press and hold the reset button for a few seconds until you see the receiver reset. Keep in mind that this process may vary slightly depending on the specific model of the Kenwood 8070 receiver.
3/6/2024 3:50:24 AM • Kenwood Car... • Answered on Mar 06, 2024
KDC-138 CD PLAYER/RECEIVER. What does code E-004 indicate?
Kenwood KDC-138 Instruction Manual [Page 18]
ManualsLib https://www.manualslib.com > ... > Instruction manual If the "E-99". code does not disappear, consult your. nearest service center. IN (Blink):. The CD player section is not operating. properly. ? Reinsert the CD.
My Kenwood KDC-d301 is giving me a E-4 error message ...
JustAnswer https://www.justanswer.com > car-electronics Aug 9, 2010 - Hello, The issue is most likely that the laser lens in the CD player itself is dirty, and not the disc. It may have been initially caused by a ... 1 answer · Top answer: You need the Kenwood radio keys that came with the unit to slide it out of the dash. It sounds ... Missing: 138 ‎' Show results with: 138
I have a KDC 138. It is stuck on OCER and will not reset.
JustAnswer https://www.justanswer.com > car-electronics > 5lw8u-... Sep 27, 2011 - This actually is DCER - you have a blown speaker. The radio is sensing a ground on the speaker circuit. Check that and let me know. If you leave ... 1 answer · Top answer: Thanks for stopping by: This actually is DCER - you have a blown speaker. The radio is sensing ... Missing: E- ‎' Show results with: E-
Cd Player Unit - Kenwood KDC-138/138CR Service ...
ManualsLib https://www.manualslib.com > ... > Service manual Kenwood KDC-138/138CR Manual Online: components description, Electric Unit, Switch Unit, Cd Player Unit. Controls Fm/Am Tuner, The Changer, Cd Mechanism, ...
2/16/2024 6:44:56 PM • Kenwood Car... • Answered on Feb 16, 2024
How to power supply of kCSWA900 Kenwood sub whooper power supply 10 pin
Take a look at this manual diagram. https://www.manualslib.com/manual/359815/Kenwood-Ksc-Sw10.html?page=5#manual Given the above is not your model, at least it shows the 10 pin. Ironically, below I offer a diagram of your model. The irony comes in the fact that the diagram appears labeled in Japanese But if you compare the two diagrams, maybe something will make sense from the one with the English labels. Otherwise, you might fire off a query to Kenwood customer support. https://www.manualscenter.com/manuals/kenwood/kscsw900-owner-manual.html Here is a 10 pin harness compatible with the subwoofer. Kenwood Subwoofer Amp KSC Wa100 Wa80 Sw10 10 Pin Harness for sale online ' eBay I don't have any information on how to power supply a kCSWA900 Kenwood subwoofer. However, I can tell you that the Kenwood KSC-SW10 compact powered subwoofer has a built-in amplifier with a 38 watts RMS power and a wired remote for control over volume level, variable low-pass crossover (50-120 Hz), and selectable phase control (0°, 180°) . The subwoofer comes with a power/ground wiring harness and preamp (RCA) and speaker-level inputs .
1/26/2024 3:58:54 AM • Kenwood Car... • Answered on Jan 26, 2024
Kenwood Excelon KDC-X592 Car CD/ MP3 Player Logo
18 questions posted
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Kenwood Car Audio & Video
Most Popular Question
forgot security code stereo
  • Car Audio & Video
