20 Most Recent
Samsung DVD-1080P8/XEU DVD Player Questions & Answers
Bought H1080/XEU dvd player
Looks like it is the problem with the DVD disc / media source. Replace the disc with another disc. Last but not least.. why dont you try connecting the DVD player and TV via HDMI cable? Sometimes older cables may cause video drops .. just guessing anyway!.
4/2/2011 8:48:28 AM •
Samsung...
Answered
on Apr 02, 2011
RESET APPEARS ON DVD PLAYER
You may have accidentally activated the reset on the unit. This is done when you hold down the FFW button on the front of the unit without any disc inside.
All you need to do is turn off the unit and turn it back on. If the word RESET still appears, get the remote control and press 1. It should work fine after that.
2/10/2011 8:06:56 PM •
Samsung...
Answered
on Feb 10, 2011
I burned a video to a CD-R and it wont play in my
You probably burned an AVI file to disk using Image Burn or some program like that. Your DVD is probably older and won't accept anything but a true DVD. Buy a $30 player that's approved for DVD-R, XVID, MP3, etc.
4/5/2010 10:06:57 PM •
Samsung...
Answered
on Apr 05, 2010
How to change region codes from only 4 to 2 & 4
1) Turn on the player with no disc in the tray
2) Press the Open/Close button to open the tray
3) Press the info button, the firmware version shows up (mine was 080220.13.B.1080PXKEG)
4) After the version info disappears, close the tray again by pressing the Open/Close button
5) At this point, it will show "no disc" at the top. Press the Info button again, and this will disappear.
6) Now type the code that applies for your region (R4 is 76884). A '4' will briefly show up at the top left corner
7) Now press 9, and 9 will show up in the top left corner
8) Power off the player, and turn it on again. You'll have a multi region player
Enjoy
7/29/2009 6:20:36 PM •
Samsung...
Answered
on Jul 29, 2009
Problem hooking dvd-1080p8 to 22inch 720p RCA TV LCD HD .
I changed the output on the Dvd player to720p and that seemed to cure the signal problem,that is what the TV is,so that makes sense,I had already assumed that would do the trick.However,as I said yesterday,the manual states it only upgrades the signal in 1080p,I went by the deacription on the box which said it was compatible with all 3 signals.So after all of that I am not sure if it is going to upgrade the signal to 720p,if you have the answer I would appreciate knowing,I can certainly live with this .but it would be nice to know.
12/28/2008 7:21:45 PM •
Samsung...
Answered
on Dec 28, 2008
Samsung un55nu6950fxza TV
These LEDs are very susceptible to static electricity damage. What happens when they get zapped is a tiny threading fault starts in the LED crystal. The aluminum contact metal starts migrating into the crack, makes it wider and longer, and eventually goes all the way through the LED and shorts it out. When that happens, the metal overheats and burns out the LED so the entire string goes dead.
What this means for you is that the original LED may have been may have been zapped at the factory. The replacement strip likewise, or when it was removed from another TV (if it is a used part), or when you put it in. It should have been in anti-static packaging. You have to be very careful not to touch any of the circuitry on the LED strip, and make sure you ground your hand to the TV metal both before picking up the LED strip and right before connecting the strip to the TV. Better yet, use an anti-static wristband connected to the TV frame.
It is possible that the LED driver for that string is pushing too much current, but that's not likely. You would probably notice that part of the screen is unnaturally bright.
2/5/2024 6:37:37 PM •
Samsung...
Answered
on Feb 05, 2024
Brand new Samsung 77 OLED tv. Got knocked off the stand and fell on and bent the lower corner
It sounds like your TV has a display issue, likely caused by physical damage to the screen due to the bend. Repairing a damaged screen can be quite expensive, often nearing or exceeding the cost of a new TV, especially for larger screens like the one you described.
Here are a few options you might consider:
- Sell it as is: You can try selling the TV in its current condition, clearly describing the issue with the display. Some buyers may be interested in purchasing it for parts or attempting a repair themselves.
- Attempt a DIY repair: Depending on your technical skills and willingness to take on the challenge, you could try to repair the TV yourself. However, this can be risky and may void any remaining warranty. There are online tutorials and replacement parts available, but again, this route requires some technical expertise.
- Professional repair: You could contact a professional TV repair service to get an estimate for repairing the screen. Be sure to weigh the cost of repair against the potential selling price of the TV after it's fixed to determine if it's worth the investment.
- Sell for parts: If repairing the screen is not feasible, you could dismantle the TV and sell its components individually. Some parts, like the internal circuitry or casing, may still hold value to electronics enthusiasts or repair professionals.
- Trade-in or recycle: Some retailers offer trade-in programs where you can exchange your old electronics for store credit or discounts on new purchases. If the TV is beyond repair, you can also look into recycling options to properly dispose of it.
Ultimately, the best option for you will depend on the extent of the damage, your budget, and your willingness to invest time and effort into repairing or selling the TV.
2/4/2024 5:20:05 PM •
Samsung...
Answered
on Feb 04, 2024
