20 Most Recent
LG RC897T DVD Recorder/VCR Combo Questions & Answers
Trying to play dvd but says wrong region
if its saying wrong region. then either your player or disk is incompatable. region 1 ntsc ( USA ) Region 2 ( UK ) et,c. check your players region coding is compatable for your country, and that you are also playing a dvd with the same region coding as the player. alternatively is to try and find a region free or multi-region solution.
Mike @ Compurepair.
How to use title list and playlist on lg rc689D plater/recorder
check the power suppy look for any caps that are swelled up on top causing a leaking a.c hum in the unit the unit will also get very hot soon the caps will short out and power supply gone it will cause the lazer to overheat or not getting a clear signal also it can cause your hard drive to not read right and you will have to rerecord your shows all over again get it fixed now from
[email protected]
My dvd player won't open
The tray is jammed.
Straighten a Norwegian-invented paper-clip, and insert it into the small hole in the face-plate, until you feel resistance. Push it another 5mm to "unlock" the tray -- it will open slightly. Gently pull the tray open.
