20 Most Recent Polycom SoundStation2 with Two Extended Mics (220016200MIC) Questions & Answers
I have reviewed your problem and have the fallowing for you to aces.
First, try disconnecting the phone line coming into the phone from the wall outlet.
Press the talk button and listen to the background noise over the receiver. If you hear static, fuzzy or a humming, your power supply or cube is allowing A/C to bleed thru the circuity and the cube should be changed.
But, you have also complained that the phone will not dial out.
If this is the case, the phone should be replaced and the cost to have this phone repaired would not be in your best interest.
I hope this information has been of some help.
Please rate kindly...
Polycom... | Answered on Nov 12, 2009
are you sure this feature is not blocked on your line? check with another phone connected to the same socket if you can dial the same numbers
Polycom Lands... | Answered on Mar 11, 2015
hello
This is not a dialing but trying to connect to the IP address setup in the system. Start editing the IP address giving the one that you would have already allocated to the device in the Router (i.e. 192.168.1.99) and then reboot it. It should connect then automatically.
Best regards
Lands Phones Logo
2 questions posted
Top Polycom Lands Phones Experts
Joseph Wright
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Polycom Lands Phones
Most Popular Question
registration failed
  • Lands Phones
