20 Most Recent
Pioneer DEH-P4000UB CD Player Questions & Answers
Pioneer error code 23
Well,
Error Code 23 This display adapter is functioning correctly This device is not started.
I had the same problem with my Pioneer AVH-P4000DVD. Just got my 16GB sandisk micro cuzer in the mail from Radio Shack. Here is what I did to solve it:
- Copied all the files that came with the Sandisk device to another location (in case I need them again)
- Copied all the music I had put on the Sandisk since I got it to another location
- Using a Windows PC, I right clicked on the drive in Windows Explorer and selected "format"
- I re-formatted the cruzer mini to FAT 32, default size (yes, I know it was FAT 32 already)
- Copied the music back to the cruzer mini
- Plugged it into my radio and it works GREAT! instant access to any track
Before you do this: Reformatting the drive also gets rid of the software that makes the cruzer mini copy files super fast. It will take a lot longer to copy music to the drive. For me this is no big deal as the only reason I bought the drive was to put a bunch of music on it and then leave it in my truck
7/10/2019 3:44:59 AM •
Pioneer...
Answered
on Jul 10, 2019
RADIO CUTS OFF WHEN VOLUME IS TURNED UP
It could be your wiring as well. Sometimes, when speaker wire gets cut and grounded, like your factory wiring to your door speakers or you tap into facrotry speaker wires to add more, the load on your deck increases. When the volume gets to a certain level, it will cut off because of the heat produced to maintain the load.
9/30/2012 8:03:39 PM •
Pioneer...
Answered
on Sep 30, 2012
Pioneer DVH3290UB car DVD player.Screen just
Press and hold SRC until unit turns off. Press MULTI-CONTROL and hold until CLOCK SET appears in display, then release. Press MULTI-CONTROL to select Hour or Minute.
12/11/2011 9:55:42 AM •
Pioneer...
Answered
on Dec 11, 2011
How do i set the clock on a pioneer deh-p4000 supertunerIII
In the far right corner is the "A" (Audio) button.
Turn the stereo off
and hold the "A" button until the clock comes on.
The hour will be
blinking.
Use the up and down "Select" keys to set that.
Then use the
right "Select" key to switch to the minutes. Use the up and down keys
to set the minutes.
Push the "A" button when you're done.
10/2/2011 9:52:01 PM •
Pioneer...
Answered
on Oct 02, 2011
