20 Most Recent
Alpine CDA-9884 Car CD/ MP3 Player Questions & Answers
It seems as my stereo is locked up. I can't
Your question is lacking some detail , is this a stock radio , after market , and what brand and model . Pictures can help , depending on the siuation code be s radio key is needed or if it's after market do you have a remote ? Try to change stuff with that , could be buttons inop or worst case it's just done. Good luck
Replacing knob on Alpine CDA-9884
Don't
Good Day!
Replacement volume knob can be simply plug in, it costs $12.25 from
hereyou just have to check the slot at the back to where the handle of the potentiometer goes through
see the image below. It might need you to add pressure when inserting it.
I have a Alpine CDA-9884
XM is provided free at acquiring the systems expexted to remain fucntional for a year until user subscribes to sustain the experience thereafter. Contact the installation technical facility also to ascertain that anyy malfunctions may not have occured with device before attempting to re subscribe to xm radio. Once confirmed regular ssytem funcionalities, additional features are availbel for upgrades for user experiences.
I dont know how to
You can download the complete instruction manual in PDF format by clicking this
link.
The detailed steps for setting the time are given on page 7 of this manual.
Adobe PDF Reader is required to view this manual.
Download Adobe ReaderHope this helps. Thanks for using
FixYa.
CD player is skipping.
if you can gain access to the top of the radio, you can try cleaning the laser lens very gently with a qtip and rubbing alcohol.
Hi . . my alpine
the red wire needs to be connected directly to the battery postive/red lead. you may have to run a wire from the battery, through a hole drilled in the firewall, into the red lead on the back of the stereo. it is suggested that you use a fuse, but is not necessary, as close to the battery as possible.
I have a cda 9884
If you have connected the new cable correctly , and you have the system turned OFF... plug the MP3 player in and then turn the system ON ... it should recognise the new equiptment... and allow you to play the MP3 player.
