20 Most Recent Genius BT-03A Bluetooth Headset Questions & Answers
0answers
My nokia E63 wont find bluetooth headset
I had a similar problem with my headset.. but found the solution.. I am using Jabra 2010.. ok.. so just switch "off" the headset...go to the pair menu on e63.. then switch on the headset.. and then look for new pair devices option.. voila it came up. hv been trying for almost 3 weeks before i got the sequence right.. somehow if u had switched the headset on beforehand.. it wouldnt recognise it only.. the solution is here at jabra website .. although.. they dont hv e63 listed .. but the same procedure for e71 worked fine for my handset..
9/17/2013 4:23:40 PM • Genius BT-03A... • Answered on Sep 17, 2013
Driver for bluetooth headset Genius BT-03A
go to add hardware option and search your device and when it says to install the software select the option to install it automatically and then you will be asked for an internet connection and the software will be installed automatically
4/7/2012 8:56:11 AM • Genius BT-03A... • Answered on Apr 07, 2012
0answers
Not able to pair my bt-03a with my android device
Have you already tried to put your headset in pairing (discoverable) mode first? Anyway, in order to do it, starting with it turned off, press and hold the 'Play' button for some 7 seconds, until the indicator light is alternately lit in blue and red. It is in pairing mode now. Then, withing a couple of minutes, on your phone, go to 'Menu > Settings > Wireless & network > Bluetooth'. If the bluetooth radio is not turned on, turn it on. Then, tap 'Scan for devices'. After a little while, your headset should appear on the phone' screen. Tap over it to make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros, without the quotes). If the pairing process is succesful, your headset should enter the stand-by mode. An indication that a heaset is connected should appear on your phone too. If your phone indicates that only phone calls are available, tap and hold over it, until a context menu comes up, and select 'media', in order to make streamed music ffrom your phone sound on the headset.Hope it works for you.Anyway, please, let me know if you need further informations.Regards,Carlos
2/14/2012 11:23:49 PM • Genius BT-03A... • Answered on Feb 14, 2012
I cannot pair my nokia
Make sure the blue-tooth headset is charged
Make sure the phone is set to automatically detect new blue-tooth device.
On the headset, press the power key for five seconds until the RED light blinks quickly.
Phone should detect headset within 10 - 30 seconds. It should eventually say BT-03A then ask for aOnce it does, type 0000 into the phone when it asked for a device ID.
5/5/2011 2:20:29 AM • Genius BT-03A... • Answered on May 05, 2011
CAN'T CONNECT jabra 210 AND nokia e63
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
1/5/2010 1:58:04 AM • Genius BT-03A... • Answered on Jan 05, 2010
0answers
0answers
0answers
0answers
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
  1. Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
  2. Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
  3. Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
  4. Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM • Radio... • Answered on Apr 19, 2024
2answers
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM • Radio... • Answered on Apr 04, 2024
Genius BT-03A Bluetooth Headset Logo
Popular Tags
16 questions posted
Top Genius Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Genius Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Genius Radio Communications
Most Popular Question
connect jabra 210 nokia e63
  • Radio Communications
