20 Most Recent
Plantronics Hama Voyager 520 Bluetooth Headset Questions & Answers
I am having trouble pairing
Hold the power button for 6-10 seconds when ps3 is searching- light will flash red and blue on the headset-- good luck getting it to work in Black Ops though.
After i try to turn it on, I get 1 blue flash and
When you turn on your headset, the blue light indicates it's on and
the three red flashes indicates a charged headsets. If it's not
turning on after that, try resetting the headset (turn off and on).
Turn it off by pressing the call control button until the indicator
glows red (you'll hear descending tones). Once off, turn it on in the same way (you'll hear ascending tones).Good luck from
Headsets Direct!
Cannot pair my nokia N6730c
You want to remember that newer phones are like small computers, so
they may become corrupt over time and you may need to reset them every
so often. Simply turn your phone off and remove again the battery for
a few seconds, then replace the battery and turn it back
on again. Then carefully follow the pairing instructions in the attached link.
Plantronics Voyager 520 User's GuideGood luck from
Headsets Direct!
Passkey to connect to samsung
When prompted for the password, enter 0000 and this will allow the headset to successfully pair with your phone.When pairing is successful, the indicator on your headset flashes blue. Your headset is now connected and ready to use.Hope you are satisfied with my solution.If you need further assistance please post me a reply.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
What does it take to get a copy of the manuel for
It will take just a click from you to have your manual and print it out. Here is the link.
http://www.google.co.in/url?sa=t&source=web&cd=5&ved=0CDYQFjAE&url=http%3A%2F%2Fwww.plantronics.com%2Fmedia%2Fmedia_resources%2Fliterature%2Fuser_guides%2Fvoyager520_ug_en_us.pdf&rct=j&q=free%20download%20manual%20Plantronics%20Hama%20Voyager%20520&ei=-8EWTaHoDsWHrAeireD5Cw&usg=AFQjCNHUHcRCwNGoLVfPsJdJpB1iG-YO3A&cad=rja
Code pin
hello, usually 0000 or 1111
regards
shaun
