20 Most Recent
Blueant Z9i Bluetooth Headset Questions & Answers
My BlueAnt won't go into pairing mode anymore!
Have you tried resetting the Blueant Z9i? You push the Volume Up, Volume Down and Blueant buttons all at the same time (with the device on). This will eliminate all paired phones, then re-pair with just your phone (hold down Blueant button for 6 seconds or so to enter pairing mode).
I have an I phone and use the Z9i headset. I am
I reloaded the latest software update on the Headset 3 times (each time it said it had been updated and reloaded) finally the last reload did fix the problem. Unknown to me why this worked this way.
Hello
i have a new phone
press on or volume button for 5 to10seconds,light will blue and red blinking.now search for device in phone.
I need to get a
- Hope this helps and thank you for using FixYa
Regards,
Tony
Z9i Connecting problem.
Its not pairing, i previously
To reset the Z9i to factory settings; while in idle mode (not
connected to any device), Click Volume , Volume and MFB together (3 buttons). The Z9i will refresh its
memory, delete all current pairing information and automatically go into Pairing mode (LED will fl ash Blue) ready to pair
with a new device.
Clear memory on blue ant z9
- To reset your Z9i it must be switched on but not connected to any devices.
- You should already have deleted the pairing information from your phone, but if you have not, use your phone's Bluetooth menu to disconnect from the Z9i and delete the pairing information.
- Now reset the Z9i by holding down "Vol +" and "Vol -" and then clicking the BlueAnt button.
- The Z9i will refresh its memory, delete all current pairing information and automatically go into pairing mode.
My iphone 4 cannot discover my BlueAnt Z9i. I put
First you must turn your power to the blue tooth to on in the phone menu,then you have to put your blue tooth device in discovery mode,most blue tooth device manufactures use the power button,by holding it down for 6 to 10 seconds when turning on the device it should have a solid light the you can add or search for device ,they will pair if you have your power on and your device in discovery mode once they pair you will have to enter a pin or pairing code.Most blue tooth device manufactures use a 4 digit pin pairing code they are as follows 0000,1234,1111, or 9999 i hope this helps
My Bluetooth cannot paired with
On
your phone, make sure bluetooth is turned on (settings, general).
While
your phone is in discovery mode, turn your bluetooth device on and put
it in discovery mode (usually you have to hold the power button for 7-10
seconds).
Your phone will find the device, and you will be
prompted to enter the devises PIN number (often 0-0-0-0). Your phone
should pair with the device then.
Blueant Z9i Volume control problem
To isolate the source of the issue, test the device on another model of phone. If the issue carries across you know its the unit, if not it could be the default call volume of the phone.
Rylan
