20 Most Recent
Digital Products International Clok Smooth iPod Docking Clock Radio TCR368 Questions & Answers
Can't set time or alarm
Hi
Please follow these instructions to set the time/alarm on your Clok Smooth docking station---
Time setting—
1. With the unit powered off, press and hold the "Clock/Display/Play/Pause Button" for at least 4 seconds.
2. While holding the "Clock/Display/Play/Pause Button", press the "Hour" and "Minute Buttons" to adjust the hour and minute on the time.
3. When the correct time is selected, release the "Clock/Display/Play/Pause Button" to set the clock.
Alarm Setting—
1. With the unit powered off, press and hold the "AL1" or "AL2" Button for at least 4 seconds.
NOTE: An alarm icon will begin to flash on the LCD display.
2. While holding the "AL1" or "AL2" Button, press the "Hour" and "Minute Buttons" to adjust the hour and minute on the alarm time.
3. When the correct time is selected, release the "AL1" or "AL2" Button to set the clock.
4. Press the "AL1" or "AL2" Button consecutively to switch alarm one and alarm two between sounding to a buzzer, the currently set radio station, or a docked iPod.
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
My DC plug in is
you can get a replacement from any electronics accessories store within your vicinity or order online from the below link:
http://www.qsradio.com/DCpower.htm
Best regards.
The ipod will not charge
I just tried calling the company....what a joke that was...anyway, there is a reset button on the bottom of the radio.....you can press the reset button with something like a paperclip. This should reset your settings and hopefully start to charge the iPod while docked.
How to set clock clok tcr368
Setting the CLOK TCR368 is done by having the unit:
Turned OFF - The power button is located at the top left face of the unit.
Press and hold the CLOCK/DISPLAY/PLAY/PAUSE button for at least 4 seconds. (It is located to the right of the power button at the upper left corner of the unit.) Do not let go of the button.
While holding down the CLOCK/DISPLAY/PLAY/PAUSE button, press the HOUR and MINUTE buttons to the correct time.
Release thethe CLOCK/DISPLAY/PLAY/PAUSE button.
The backup battery is to keep the clok circuit running in case of a power failure and can't be used to power the radio.
With the unit OFF, press and hold the FUNCTION button (located between the ipod slot and the snooze button) for at least 2 seconds. The display will flash either 12 hour or 24 hour depending what mode it is in.
Release the FUNCTION button and press it once to change the mode.
Press again to cycle between the 12 hour and 24 hour mode.
When the display indicates the mode you prefer, simply wait 2 seconds for the clock to go into that mode without pressing anything.
Can't choose alarm song on iPod
The best way is to select the song you want to play is:
1: Select the song and start playing it using your iPod
2: Pause the song
3: Plug the iPod into the clock
Next time the alarm goes off it will use the song currently selected on the iPod. Hope this helps.
Military Time
Press the "function" button for a couple of seconds. The display will indicate 12hrs or 24hrs.
Use the minute or hour to change the setting for 12hrs and you'll have normal time again.
I hope this helps!
I can not figure out
1. With the dock station off (none of the functions are highlighted) press and holdthe Clock/display and/or Play/Pause button.
2. After holding for up to 5 seconds (still hold) press the hour or minute buttons to adjust th ehour and minute
3. Once you are done, release your the clock/display and/or play/pause button
