20 Most Recent Acer X1160 DLP Data Projector, 2,000 ANSI, 2,000:1 Contrast Native SVGA - 800 x 600 res Projector Questions & Answers
I have a dlp acer projector when i connect it to
Kindly contact to Co's service center.
6/28/2021 2:40:17 PM • Acer X1160 DLP... • Answered on Jun 28, 2021
2answers
Black and white picture and white spots
if it is the color wheel issue, you can replace it, i have this acer X1160 color wheel, if you need please contact me
4/6/2016 12:49:18 PM • Acer X1160 DLP... • Answered on Apr 06, 2016
I just purchased an Acer X1160 Projector and
Your computer is probably using the projector as a second screen instead of displaying a copy of the laptop screen.
The quickest way to confirm is to try moving your cursor (mouse) off the right-hand side of the screen. Does it then show up on the projector? If so, then you can grab and move windows back and forth between the two screens.
If that solves it for you, please be sure to click the thumbs-up.
If not, add a comment and I'll try to explain
9/27/2014 8:26:46 PM • Acer X1160 DLP... • Answered on Sep 27, 2014
0answers
Acer x1130p
Be the first to answer 6/17/2014 1:13:17 AM • Acer X1160 DLP... • Posted on Jun 17, 2014Be the first to answer
0answers
My projector x1160 is displaying white dots all
Check how many hours your bulb has used as it will start to break down on the inner chrome coating.
10/7/2013 6:53:07 PM • Acer X1160 DLP... • Answered on Oct 07, 2013
2answers
Full with white stuck pixel
make a cleaing, if it still is full white dots, it should be problem of DMD chips,buy a 8060-6038B DMD chips and instal it. only cost USD184
9/7/2013 2:17:43 PM • Acer X1160 DLP... • Answered on Sep 07, 2013
Stars on screen of acer x1160pz
Sean ,the problem is not the bulb but is the digital micromirror device (DMD chip) is aging,that sends pixels directly to projected image.So you can replace it depending on the price you will compare.if expensive then buy a new Data Projector.
4/19/2013 9:48:21 PM • Acer X1160 DLP... • Answered on Apr 19, 2013
2answers
My acer X1160 data projector
I have the same problem and I can't find a solution anywhere.
2/25/2013 8:26:34 PM • Acer X1160 DLP... • Answered on Feb 25, 2013
2answers
My acer projector have a white dots whats the cause
It is because of the DMD chisp faulty, you have to buy a DMD chips replaced. fortunately, this model DMD chips is 8060-6038B, it is not expensive, and normal, for any fuIt is because of the DMD chisp faulty, you have to buy a DMD chips replaced. fortunately, this model DMD chips is 8060-6038B, it is not expensive, and normal, for any further help, please contact merther help, please contact me
1/12/2013 5:53:48 PM • Acer X1160 DLP... • Answered on Jan 12, 2013
Picture is upside down
You will have to go into the settings/display menu. There are image options to select from in there. If you are celing mounting then select that and if you are setting on the table select that setting. Either way it is a setting for how it is being used.
1/7/2013 11:18:42 PM • Acer X1160 DLP... • Answered on Jan 07, 2013
2answers
My Acer X1130P has white
You will most likely have to get the DMD chip replaced. I suggest you get a quote from the local Acer agent as to how much it would cost for this repair.
12/1/2012 10:15:14 AM • Acer X1160 DLP... • Answered on Dec 01, 2012
White dots on the screen
Need more info. But initial suspicion is there is a problem with your projector.Are they stationary and always in the same position? You may have bad pixels.Are the dots there with no signal going to the projector?What is connected the the projector? Detail the video path - try all the sources. The dots still there and in the same position on all sources?It is probably your projector.If some of your sources are fine - the problem might be from a connected source.Hope this helps.
8/26/2012 11:24:54 PM • Acer X1160 DLP... • Answered on Aug 26, 2012
Acer X1160 DLP Data Projector, 2,000 ANSI, 2,000:1 Contrast Native SVGA - 800 x 600 res Projector Logo
56 questions posted
Top Acer Office Equipment & Supplies Experts
SmartAviator
SmartAviator
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Acer Office Equipment & Supplies
Most Popular Question
stars screen acer x1160pz
  • Office Equipment & Supplies
