20 Most Recent
Sharp PG-A20X LCD Projector Questions & Answers
How can i reset de lamp time
With the projector running hold the right cursor key, down cursor and the enter button down switch the mains power off.
Still holding these buttons down power the projector back on. it will take a few secounds for the lamp to light up.
When it does you should see lamp hours 0000
Hope this helps
System lock of my projector sharp 50s ,so how to unlock?
- Check the Remote: Make sure you have the remote control for the projector.
- Press the Menu Button: On the remote, press the "Menu" button.
- Navigate to Security or System Lock: Use the arrow keys on the remote to navigate through the menu options. Look for a section related to "Security" or "System Lock."
- Enter the Unlock Code: If you previously set a system lock code, you will need to enter it using the remote control. If you haven't set a code before, try the default code (often 0000 or 1234).
- Disable System Lock: Once you've entered the correct code, navigate to the option to disable or unlock the system lock.
- Confirm: Follow the on-screen instructions to confirm your choice, and the system lock should be disabled.
Sharp EL-1197PIII printing nonsense after a jam.
Reset the calculator: Locate the reset button on the bottom or in the battery compartment and press it .
Clean the printer head: Use a soft, dry cloth to clean the printer head and ensure that there is no debris or paper stuck in the printer mechanism .
you are looking for resources to properly align the gears. I found a few resources that might be helpful:
Sharp EL-1197PIII Operation Manual: This manual provides detailed instructions on how to operate and maintain your calculator, including how to align the gears. You can download the manual from the following link:
SHARP EL-1197PIII OPERATION MANUAL Pdf Download ' ManualsLib.
Sharp EL-1197PIII User Manual: This manual also provides instructions on how to align the gears of your calculator. You can access the manual online from the following link:
Sharp EL-1197PIII User Manual online (mans.io).
Sharp EL1197PIII Heavy Duty Color Printing Calculator User Manual: This manual provides instructions on how to align the gears of your calculator. You can download the manual from the following link:
User Manual Sharp EL1197PIII Heavy Duty Color Printing Calc ' manualsFile.
My fridge won't stop beeping though door is closed
Posibllities to eliminate: 1) bad door seal 2) unbalanced fridge on floor 3) buildup of ice in fridge (defrost) 4) faulty door alarm.
Check temp of fridge. Adjust up or down depending on whether too hot or too cold. Check for blocked air flow or too many items in freezer. But if the exterior is much warmer than usual, you may be looking for a repairman. The main circuit board might be blown
Try a reset by unplugging it for 5 minutes, then plugging it back in. If a minor problem, this may stop the beeping.
Can I order a sensor for my sharp spc908
Maybe worth a look through this catalogue but I doubt spares are available;
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&ved=2ahUKEwjizJ7-k92DAxWzQkEAHUqwDmQ4ChAWegQIBxAB&url=https%3A%2F%2Fwww.specialized.net%2Fmedia%2Fwysiwyg%2FSpecialized%2Fetc%2FSpring-2023-catalog.pdf&usg=AOvVaw2Z06h4GZtS13wC9OK0rLZl&opi=89978449
