20 Most Recent
DBX 2231 Home Equalizer Questions & Answers
One channel ceased to work.
The part is a 4560 (generic opamp IC. The damaged IC is more likely to be the symptom not the cause Remove the IC and the cap. Replace the cap, but not the IC and measure pins 4 and 8 to ground. These should be the power inputs and measure +/- 5 thru 12 volts. They should be equal but opposite. Should htey be different, check the power supplies or any filter caps.
Update this with the results.
Thanks,
Dan
Washer water stays running
There is a solenoid that controls the hot and cold water. If you turn off the washer and the water stops, there may be an issue with one of them. If it continues to flow you may have one stuck open.
1/22/2015 11:03:31 PM •
DBX Audio...
Answered
on Jan 22, 2015
