20 Most Recent Onkyo HT-S3100 Receiver Questions & Answers
It sounds to me that some part of the circuit possibly an IC is overheating after several hours and develops a fault.
This will be a very tricky thing to track down. So maybe best to take it to an authorised service agent.
Onkyo HT-S3100... | Answered on Oct 18, 2017
No. If you hook up more than one speaker to a single output, you will drop the impedance that the receiver sees and probably blow the amplifier.
Onkyo HT-S3100... | Answered on Jun 03, 2013
80hz.. if you are using the factory speakers.
Onkyo HT-S3100... | Answered on Aug 05, 2011
www.intl.onkyo.com/downloads/manuals/.../ht-s3100_manual_e.pdf -
Hi, please find above your user manual, and below your service and repair manual. These will help you to workout what to do, and how to reset your system. Usually simply removing it from the power will reset everything, except fro NVRAM entries, but the Tape is not one of them, so i wonder if you may not have some other sort of problem, use the service manual to check.
http://elektrotanya.com/onkyo_ht-r340_ht-s3100_3105_sm.pdf/download.html
Onkyo HT-S3100... | Answered on Sep 12, 2010
Palaboy is incorrect. JBL Control 1 speakers are 4 Ohm 150 watt speakers. He's probably thinking of the Control 1x speakers which are 8 ohm 80 watt speakers.
If you hook your Control 1s to that Onkyo, it won't sound great and could cause the receiver to overheat and trip the protection circuit if played at high volume.
Onkyo HT-S3100... | Answered on Dec 16, 2009
Impedance must be matched to have a better sound performance. Althought, it has no problem b/w 4 Ohm and 6 Ohm impedance-it still work but the system may get hotter due to impedance mismatching. You can try and see how the sound goes.
Onkyo HT-S3100... | Answered on Aug 12, 2009
Hello
If you have the original remote
check the display button or dimmer button.
If you don't get any illumination from the display screen, that means that display florescent is at the end of life needs to be serviced.
Regards.
Onkyo Audio... | Answered on Sep 09, 2019
HI
Power Transistors
2SC5200
2SA1943
OR equivalent.
Good luck
Hello
Your AVR is in protection mode
Check Speaker cables if there is a short circuit or defected speaker. can also do the same thing.
If non of the above.
you need to service the AVR .
Good luck
Hello Brenda
Where do you want to hook your ONKYO and with what you want to connect it to.
There are several steps and a lot of devices can be connected to the Onkyo.
1 Speakers are to be connected on the rear side of the device. as it shows in and on the Instruction manual If you have it.
And for other devices each device has its way of connectors.
Optical to optical and RCA to RCA ...
IT depends on What kind of devices you have.
Hello Brian
1: connect your fire tv to any HDMI input on your Onkyo AVR.
Make sure you know which input and select it by the remote. or by the selector keys on the AVR front panel.
2: The HDMI output from the Onkyo AVR, goes to the HDMI input of your TV...
I hope its Clear.
Good Luck Plugging HDMI Cables.
Hello
Did you update the AVR over the internet?
If so the device wont work anymore.
You need to service the device in a nearest Onkyo service department.
Regards
Hello Mario
1: check connection properly.
2: test Speakers left and right on the channel that is working.
Do you have HDMI built in the AVR or not?
Some models does not have HDMI.
Try and give a feedback.
Hello
There are a lot of customers having the same issue.
It is a manufacturer defect.
Sorry for you.
Hello
what kind of a preamplifier you are using between the Turntable and the Amp.
please take a photos of the preamp from inlets and outlets.
so i can figure it out.
Regards.
Hello
When the device stay on STBY it means it is in a protection mode.
means also safe mode so it wont make more damage.
Try this my friend.
1: please check speakers cables.
If you have some knowledge in Electronics
test on the supply board in/out volts and power Amp voltage (Not on the transformer)
check with diagram as shown
Onkyo HT-S3100 Receiver Logo
9 questions posted
Popular Products
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Onkyo Audio Players & Recorders
Most Popular Question
just bought system like toknow hook up
  • Audio Players & Recorders
