20 Most Recent
MXL 990 Professional Microphone Questions & Answers
I need replacement rings for the suspension.
I take itypu are talking about the elastic bands for the isolation of the mic. You should be able to find some on eBay or by contacting the manufacturer. Some parts houses carry those items as well. B&H Photo would be a likely one.
2/2/2015 6:41:27 PM •
MXL 990...
Answered
on Feb 02, 2015
Repair
If you are good at doing such things yes, but the parts inside are very delicate and must be handled gently as not to damage them. If you are not comfortable doing it then I would suggest taking it to a local music store where similar items are sold to see if they can do it for you.
1/24/2015 11:20:38 PM •
MXL 990...
Answered
on Jan 24, 2015
No sound from mxl 990 condenser mic
From the Micropower PS400 product description it states:"routes the microphone signal to a mixer or a microphone preamplifier." • these is just a phantom power supply.One reason your former setup is OK , is that tascam m-50 is a mixer preamplifier. • phantom power supply is just a part of the mic preamp of the mixerto power up your mxl 990 condenser mic • What you may need is something like these:
X2u XLR to USB Signal Adapter
10/1/2012 10:27:05 AM •
MXL 990...
Answered
on Oct 01, 2012
Is the 990 an externally polarized capsule or
The MXL 990 is an externally polarized condenser microphone. You will nee to provide 48v Phantom power to use it. Alternatively there is a USB version, the MXL 990 USB which gets it['s power from the USB port.
1/1/2011 6:57:39 PM •
MXL 990...
Answered
on Jan 01, 2011
MXL 990 has really low output
These are really cheap mics! I have two dozen of them because what I do requires the mic to be expendable. The capsule is pretty fragile and just a little drop or hit to the mic can drastically alter the frequency response and output level. If you record with it and it has a hollow sound I would bet this is what happened. If you can generate white or pink noise out of your system, then record it. Just hold the mic in front of the speaker. Play it back and compare the tone of the recording to what you just heard. Hollow? There you are!
10/15/2008 6:54:27 PM •
MXL 990...
Answered
on Oct 15, 2008
My marshall MXL V67 MIC doesn`t work
If this is a condenser micrphone it will require Phantom Power from the mixer you are trying to use it with. If Phantom Power is provided, check the cable to ensure proper wiring.
1/24/2015 11:10:45 PM •
MXL Audio...
Answered
on Jan 24, 2015
Does djx750 use phantom power
F rom what I see in the user manual no, only a dynamic mic can be used with this unit. A comdenser mic will not be powered.
1/24/2015 11:07:35 PM •
MXL Audio...
Answered
on Jan 24, 2015
Is there a battery in a mxl 992?
Has it a remove able cover or on the plug? Normally it has the word "Electret condenser" on the body. Is it a lapel type ? Modern units are invariably of this type.
6/29/2014 5:17:39 PM •
MXL Audio...
Answered
on Jun 29, 2014
