20 Most Recent
Polk Audio DSW PRO 500 Subwoofer Speaker Questions & Answers
No power. Fuse was blown but replaced fuse and still no power.
If fuses blown there is a case to search for short circuited active parts examples are end-transistors caused by clipping speakers cable shorts leaking or convexed capacitors but any new fuse will blowing again and again also the bridge rectifier to make dc voltage inside the power supply of the subwoofer can caused this problem
Polk Audio DSW Pro 500
Is this NEW? Or did it just fail spontaneously after working for awhile?
Is this just a remote control issue or is the sub dead, too?
From the manual...
No sound coming from subwoofer.
If hookup is "SUB OUT" to LFE, check and make sure your receiver is set to Subwoofer=YES. If hookup is via speaker wire, check that the polarity of the wires is correct.
Subwoofer has no power.
Is the AC MAIN switch on? Check outlet; check fuse after unplugging the subwoofer. The fuse is located under the power cord
receptacle. Fuse type and rating is found on the back panel.
Remote control doesn't work.
Remove the plastic tab to activate the remote control's battery or try replacing the battery. Ensure the IR sensor is not blocked.
If it's a new problem with a previously working remote...
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12954406270641
It describes a way to possibly fix your remote or at least prove it works or doesn't.
Find new or replacement remotes:
http://remotes.com/remotes/servlet/rs?a=Display&contents=home&uuid=A12992635562861
or eBay: search for "(model) remotes", check the 'include description' box. Usually cheaper than the vendors.
Got a brand new dsw
if there is multiple jacks on the sub be sure they are hooked up correctly simple mistake if not no doubtly a simple overlooked setting on your amp good luck you will get it
Polk audio pa660 is in protection mode how do I reset it.
Lots of help in the links
Amp goes into protection mode - Polk Audio Forum
https://forum.polkaudio.com > discussion > amp-goes-i...
Nov 26, 2018 - As the title says , my 4 channel amp goes into protection mode when I turn my volume up to about 18-20 , causing a loss of sound .
Solution to my Protect Mode Problem - Polk Audio Forum
Feb 15, 2010
Speakers causing the Power Amplifier to go into protection ...
May 9, 2016
PA D4000.4 starts up in protect mode? - Polk Audio Forum
Aug 22, 2012
PA880 Help Needed - Protection Light - Polk Audio Forum
Apr 3, 2013
More results from forum.polkaudio.com
Protection Light ' Polk Audio PA660.4 Support - HelpOwl.com
https://www.helpowl.com > PA6604 > Troubleshooting
Jul 31, 2017 - Polk Audio PA660.4 - How do I turn off or get out of protection so I ca.
Car amplifier(Polk Audio PA660) question - Badcaps Forums
https://www.badcaps.net > forum > showthread
Dec 19, 2013 - The amp, is a Polk Audio PA660. It was entering in protection mode. I have found a pair of final transistors shorted at one of the ...
Amplifier Protection Mode Troubleshooting - Car Audio Help
http://www.caraudiohelp.com > newsletter > amp_prote...
One of the more confusing car stereo problems can be when an amplifier goes into protection mode. One minute it's working and the next minute it's not, ...
I have a Polk audio PWS 110 powered subwoofer. Static sound is coming from the speaker. I have checked all the connections and everything appears to be ok.
go to the hardware store and buy a cheap plug-in polarity checked for the electrical socket. If the polarity is reversed, or your ground is improper is will give you a different colored light. Polarity is easy to reverse. Shut off the main breaker box in your home and simply take the cover off the outlet and swap the two wires with the narrow and wider blades on them. Make sure the ground wire is actually grounded to something like a water pipe of connected to the house ground rod, #4 rebar, 18 inches long with a thick copper wire and brass auto batt connector will work fine... bury it deep and remember where it is in the flower bed underneath a window sill outside. If the subwoofer is near the TV, you made be getting interference from it, if the cabinet is not shielded against RF.
