20 Most Recent
Brother DCP-8065DN Black and White Copier Questions & Answers
How do I clear a scanner jam when there is no
It would be somewhere inside even a very small pieces, remove cartridge, and look carefully inside. It is very rare that the sensor is faulty and send the wrong signal. But please check carefully inside the pritner, you might find a small piece of papers stuck in there.
Good luck
Thanks
6/21/2011 4:31:45 PM •
Brother...
Answered
on Jun 21, 2011
Says toner life end and
hello
hen the toner almost end it will give you notice toner near end and you have to replace the toner and there is small button to be slide to clean the drum and also sometimes even if your replace new toner it will still appear the toner near end you have to shutdown the printer remove the powr at th wall and also at the back of the printer and wait for some time and plug it back and turn on.
thanks
4/14/2011 12:49:20 PM •
Brother...
Answered
on Apr 14, 2011
How do you reset the
In Brother DCP-8460 procedure to reset the counter is:
Open front cover a push "Clear/Back" button and on the display show "Replace or change the drum" just choose Yes and push "OK" button.
I hope I helped.
2/4/2011 8:14:54 PM •
Brother...
Answered
on Feb 04, 2011
I have changed toner and photosensitive drum but
if the lines are vertical ..than the issue is from the rollers being dirty ..and the print head..Open it with care ..and clean the rollers and the print head..and they should be gone ..
reset it after you do that ..If you do not have a reset guide in the manual ..try to classic one with removing the power cord..and keep the power button pressed while you reinsert the power cord..keep it pressed at least 10 sec ..
Here is the manual for it ..and in here there are some tabs with actions to be made in certain cases..
see the troubleshooting pages ..
About your issue they say to clean the primary corona wire..
the action is explained on page 71
http://dl.owneriq.net/8/80904590-9210-40a7-8701-2573dd139967.pdf
2/1/2011 11:20:13 AM •
Brother...
Answered
on Feb 01, 2011
How to reset the fuser
Could you please let me know the error code? If I am right, you must be getting an error. There's no way to reset this but you have to bypass it through any means (if available). Also let me know the condition of the fuser unit, whether it's hot or not. Thanks and awaiting.
9/3/2010 12:58:11 PM •
Brother...
Answered
on Sep 03, 2010
Clicking noise from Printer tray left side
Usually most of the noises are within the toner/drum unit. HAve you tried another drum/toner. Noises are funny because it's hard to pinpoint exactly where they are coming from!
8/3/2010 11:50:32 AM •
Brother...
Answered
on Aug 03, 2010
When I turn on machine, I hear a clicking noise,
To follow up on my previous confirmation of this issue, I followed the instructions on Brothers website:
http://welcome.solutions.brother.com/BSC/public/eu/gb/en/faq/faq/000000/002500/000079/faq002579_000.html?reg=eu&c=gb&lang=en&prod=dcp8065dn_all&Cat=121
The clicking has now gone. hope this helps!
8/3/2010 11:49:45 AM •
Brother...
Answered
on Aug 03, 2010
Have replaced the drum and toner cartridge and am
Vamos abra a maquina, retira o cartucho, do lado esquerdo tem uma alavanca preta (do lado de dentro da maquina), empurra ela e segura, vai com uma chave de fenda e fecha o sensor de tampa aberta q se localiza do lado esquerdo da parte da frente da maquina, apos vc fechar o sensor a maquina ira fazer o auto teste, e vai mostra Toner erro, coloque o cartucho novamente, delique a maquina fecha a tampa e liga novamente.
7/28/2010 8:33:28 PM •
Brother...
Answered
on Jul 28, 2010
It says drum needs replaced what is the drum?
In this machine it is located in the unit where you would replace the toner cartridge. It is the heart, its the imaging film like in a camera, that produces the image onto your paper.But it is a solid photo conductive cylinder in your machine, its in the cartridge that pulls out with your toner cartridge. If its life cycle has expired it needs to be replace.Goto your local office supply store and get another drum unit.
4/14/2010 3:51:41 PM •
Brother...
Answered
on Apr 14, 2010
DCP 8065DN
please print option paper source setup mp tray and setup page size then solve your problem
mp tray is copier front side open it and insert paper or print source lower casset
i pray you wiil success
12/1/2009 7:31:02 PM •
Brother...
Answered
on Dec 01, 2009
