20 Most Recent
Ricoh Aficio MP1600SPF Copier Questions & Answers
Mp 7500 sc 144
Try reposting by asking a question. We have no idea what your problem is.
Have more lines what I do
More lines when printing or photocopying?? What color lines? For lines when printing, clean charge rollers of the respective PCUs. If not, replace PCU drums. For lines that are appearing only when photocopying, check if the slit glass or flat bed glass have white out liquid correction ink markings on them. If yes, clean them. If not, clean scanner lens and mirrors of the scanner assembly.
Ricoh Aficio MP 6000 copier with error code SC555
there is no sc 555 on those machines only sc 550 and that relates to what is called a fuser web.It does need to be changed but you can reset it by pressing the following in order
1- yellow clear key
2- number 1
3- number 0
4- number 7
5- press and hold down the orange clear/stop key for 5-10 seconds.
the screen changes
select copy sp
select sp 1
scroll down to SP1902 001 and select
reset that value to 0 and select enter
switch machine off and on and that should get you going for now.
Let me know
