20 Most Recent Canon MF6530 Black and White Copier Questions & Answers
I have a canon image class mf6530 copier. I cannot
I do not have that model but when I have the binding on it does doble side, turn binding off and it is single side.
12/5/2014 5:24:28 PM • Canon MF6530... • Answered on Dec 05, 2014
Printer is printing to light for my needs...has a new toner
Verify the toner cartridge.Open the glass platen cover and make a copy,not used an original,if the cpy is a full black papier thr toner density is OK,Clean the polygon unit glass.Enter in program and perform a test page.
4/7/2013 6:49:49 PM • Canon MF6530... • Answered on Apr 07, 2013
Canon MF 6530 Paper Jams
it can be that sesor flaper in fixing unit has an slow response or the sensor is faulty. Also it can be that this is delay jam due to worn out paper feeding roller, or faulty pressure in fixing assy.
Recommendation is to call service!
9/17/2011 9:44:43 AM • Canon MF6530... • Answered on Sep 17, 2011
New canon mf4350d multi-function copier has a
I must admit that I don't know on what plastic part do You mean, but I can send You the part's catalog, inside you will find all parts # and descripton.
Leave the e-mail.
8/26/2011 1:54:22 PM • Canon MF6530... • Answered on Aug 26, 2011
My printer's feeding mechanism or
I think that is not problem with your printer,
that is cause paper was moist. and sticky.
solution make the paper became warm (put on the warm place or don't use air conditioner in this room)
5/13/2011 6:21:06 PM • Canon MF6530... • Answered on May 13, 2011
2answers
Unplugged it and now it
Welcome to Fixya
Try this troubleshooting procedure:
With the machine on, unplug machine from surge protector or outlet. While the machine is off push the Copy, Scan, Start button in that order 3 times. Plug the machine back up. The machine should initialize and be ready to copy.
Please let me know if you have furhter questions.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
5/4/2011 9:28:15 PM • Canon MF6530... • Answered on May 04, 2011
Where is the platen glass
it is located where you put original copy. and you can clean with wet cloth.
4/19/2011 10:45:31 AM • Canon MF6530... • Answered on Apr 19, 2011
I unplugged our copier, and after plugging it back
you must have to download the firmware. which can do canon engineer.
copier missing it's operting system.
4/7/2011 1:48:25 PM • Canon MF6530... • Answered on Apr 07, 2011
Paper wrinkles up time it gets about an inch in
Hello Hawk.
My name is Jeff and I work for a company named Advanced Office Systems which has been in business for over 30 years.We are based out of Knoxville Tennessee and unfortunately can't come to help.But I feel confident my service manager may be able to help you find a service provider in your area.He's a good man named Dan Llewellyn (pronounced "loo ellen").His number is 865.966.0770 ext 217. A busy man ,but a good man. I hope I have helped you so if you don't mind please acknowledge my help thru FIXYA. Thanx and I wish you the best.
1/15/2011 2:16:24 PM • Canon MF6530... • Answered on Jan 15, 2011
Frequently when I turn on the printer the red
I presume that the problem is in MFP crg. recognition.
When you remove toner crg. on right side in the MFP you will see black "gear" with one metal pin, which goes out when you close the door. Apply small amount of WD40 or similar and open close door for few times. If it does'nt helps you need to dismantle the copier and clean the whole section...
Hope that helps!
By the way didi you try with another crg.?
12/28/2010 8:55:28 AM • Canon MF6530... • Answered on Dec 28, 2010
How do we reset printer to original settings?
press *2 then 8 then *again.machine will be in service mode go to clear,then choose all then press ok machine will be in default mode,pleaze wait msg will apear,turn off and on again,i hope u will be happy
11/18/2010 9:52:02 PM • Canon MF6530... • Answered on Nov 18, 2010
Will not print
if you have problem, wich is that you have blank copies and prints, the problem is in metal pin caled laser shuter.
Call service.
6/28/2010 4:27:06 PM • Canon MF6530... • Answered on Jun 28, 2010
I have having a problem
This model have an laser shutter issue. Call service
6/14/2010 5:47:30 PM • Canon MF6530... • Answered on Jun 14, 2010
4answers
THE WORD INING COMING ON
Hi
Please can you be a bit more precise about your problem.We will try our best to assist you.
Thanks for contacting fixya .com
5/1/2010 1:40:26 AM • Canon MF6530... • Answered on May 01, 2010
Can I scan using the feeder?
Yes , that is what the feeder is used for so you should not have a problem doing so.
2/2/2010 9:31:49 PM • Canon MF6530... • Answered on Feb 02, 2010
Canon MF6530 Black and White Copier Logo
30 questions posted
old marine
old marine
ZJ Limited
ZJ Limited
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
printer 39 s feeding mechanism or
  • Office Equipment & Supplies
